Last thread for today.. when a belt flips #2947040
07/25/21 04:33 PM
07/25/21 04:33 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Flipped a gimler and std belt yesterday.
Not sure why but every time I put it back on, it keeps popping off.
Are they done?
I'm sure alignment is good.
Last pass std flipped on its side but stayed on last 2 passes but thin gimler belt blows off every pass and that the one with the very wide crank pulley.
Re: Last thread for today.. when a belt flips [Re: Sammy] #2947042
07/25/21 04:38 PM
07/25/21 04:38 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What is it driving? pics
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Last thread for today.. when a belt flips [Re: W.I.N. Racing] #2947049
07/25/21 05:39 PM
07/25/21 05:39 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
time for new belts
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Last thread for today.. when a belt flips [Re: Sammy] #2947050
07/25/21 05:47 PM
07/25/21 05:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Are you sure nothing is flexing[bracket]? Can you repeat it without driving the car looking at the belts? I agree you will need new belts anyways.
Re: Last thread for today.. when a belt flips [Re: Clanton] #2947051
07/25/21 05:51 PM
07/25/21 05:51 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Its usually a mis-alignment issue or a flexing issue....I would string it with the belt off and see what it looks like.
Re: Last thread for today.. when a belt flips [Re: Clanton] #2947055
07/25/21 06:11 PM
07/25/21 06:11 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Going to double check the alternator spacer. It might be flexing. Not sure.
Vacuum pump definitely not flexing and with the wide crank pulley, it basically self aligns and the belt is almost centered on the pulley.
Re: Last thread for today.. when a belt flips [Re: Dragula] #2947058
07/25/21 06:13 PM
07/25/21 06:13 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks... going to string it tomorrow.
Have to order new belts anyway. Vacuum pump belt has to go on 1st.
I do have a spare alternator belt. Always need spares.
Re: Last thread for today.. when a belt flips [Re: Sammy] #2947086
07/25/21 07:32 PM
07/25/21 07:32 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Just went through this on my car, I have a post on B-Bodies only I thought my alignment was good until I put a straight edge on it now everything seems good. I went through 4 belts usually once they flip I changed them out
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
