E body front disc brake question #2945387
07/20/21 09:12 PM
07/20/21 09:12 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
Good evening everyone
On my 70 Cuda, it has factory disc brakes. I recently got the rotors turned and was informed that they are at the end of their life (done by a quality business).
So original small bearing rotors are getting tougher to find new. I was looking at maybe up grading to the newer style big bearing rotor. I had recently redone the entire braking system with all new pieces. I have brand new pin type calipers.
I noticed Dr.Diff has those conversion sleeves for the spindles
If I use the later rotors and the conversion sleeves, can I use everything else (calipers, mounting bracket, etc)?
Thanks for any help given
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: E body front disc brake question [Re: TX9H6E4CUDA] #2945402
07/20/21 09:44 PM
07/20/21 09:44 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Don't see why not.
Only real difference was the inner bearing ID, & that was dictated cause of reduced spindle neck diameter.
I believe the smaller inner id bearing will go into any rotor. ??
Big headache on earlier years was the 2 pc rotor design.
Re: E body front disc brake question [Re: TX9H6E4CUDA] #2945410
07/20/21 09:57 PM
07/20/21 09:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Repro rotors are available for the 70-72 years but a little spendy, if you want to go to the 1 pc 73 up rotor it's an easy swap, buy the sleeve kit for the inner bearings, the outers are the same as the earlier 70-72, everything else bolts up to the 1 pc rotors, I've done this conversion to a few customers cars....
Re: E body front disc brake question [Re: DAYCLONA] #2945524
07/21/21 10:59 AM
07/21/21 10:59 AM
VA
dragon slayer Offline
VA
Well your not going to get 2 piece rotors, but the single are not that hard to find or pricey unless you think $60 is too much for a rotor. Rock auto has them. I have the Centrix on my RR no issue for several years now.
Re: E body front disc brake question [Re: TX9H6E4CUDA] #2945581
07/21/21 12:45 PM
07/21/21 12:45 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I still have my original 2-piece rotors on a shelf, and swapped in the 11 3/4" Police Taxi rotors. The 2 -piece rotors are more susceptible to warping under spirited use, so I don't run them. I think I upgraded to the correct spindle to avoid the sleeve issue. While I was at it, I bolted on Dr Diffs Econo rear brake kit. I have this same set-up on both my '68 and '70 Barracudas. The modulation and balance is nearly perfect. The '70 has power assist, which is almost too much assist, but it still feels nice when driving. I used an smaller than 1" master cylinder on my '68 and the brakes are great for road course work. Both cars have the Firm Feel metallic brake pads, which I highly recommend.
Re: E body front disc brake question [Re: jbc426] #2945629
07/21/21 01:53 PM
07/21/21 01:53 PM
moparx Offline
moparx  Offline
has anyone used a drum brake hub and a [common ?] slip-on rotor [like used on new stuff] with the disc brake spindles ?
providing a correct diameter and hat offset, as well as the correct hub register could be found.
would this type of rotor be feasible to use ?
just thinking again. [dangerous, i know...... laugh2]
beer
Re: E body front disc brake question [Re: dragon slayer] #2945638
07/21/21 02:11 PM
07/21/21 02:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed the repro 70-2 "2 pc" rotor is cast in one piece, and is an alternative to those that don't want to run the bearing shells in the 73 and up unicast rotor on the 70-2 spindles....
Re: E body front disc brake question [Re: DAYCLONA] #2946052
07/22/21 02:37 PM
07/22/21 02:37 PM
minnarusta
minnarusta
Awesome everyone, thank you again for the help!!!
