LM2 replacement sensor? #2944474
07/18/21 08:42 AM
07/18/21 08:42 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
The O2 sensor for my LM2 has given up the ghost. What are y'all using for a replacement?
Thanks, Justin
Re: LM2 replacement sensor? [Re: justinp61] #2944480
07/18/21 08:53 AM
07/18/21 08:53 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I found this years ago and use it as a reference.
Re: LM2 replacement sensor? [Re: YO7_A66] #2944498
07/18/21 09:56 AM
07/18/21 09:56 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They call for a 4.9 now. Compatible with the 4.2 except for the plug if I'm reading it correctly.
https://www.innovatemotorsports.com/xcart/bosch-lsu-4-9-o-sensor-p-n-3888.html
Kevin
Re: LM2 replacement sensor? [Re: Twostick] #2945601
07/21/21 01:10 PM
07/21/21 01:10 PM
PA
moparacer Offline
moparacer  Offline
PA
Kevin
If you switch to the 4.9 don't forget to change it in the setup. up
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: LM2 replacement sensor? [Re: moparacer] #2945627
07/21/21 01:48 PM
07/21/21 01:48 PM
W. Kentucky
W. Kentucky
What's the advantage of the 4.9 sensor?
Re: LM2 replacement sensor? [Re: justinp61] #2945681
07/21/21 04:08 PM
07/21/21 04:08 PM
PA
moparacer Offline
moparacer  Offline
PA
To make a long story short, it's better....
https://www.ecotrons.com/accurate_lambda_meter/bosch_lsu_49_is_superior_to_lsu_42_sensors/
Uses current instead of air, for reference. Much past that I am lost.... shruggy
Re: LM2 replacement sensor? [Re: moparacer] #2945692
07/21/21 04:29 PM
07/21/21 04:29 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does that eliminate the free air calibration?
Kevin
Re: LM2 replacement sensor? [Re: Twostick] #2945774
07/21/21 08:06 PM
07/21/21 08:06 PM
PA
moparacer Offline
moparacer  Offline
PA
Kevin
It seemed to on mine. Been using it all summer on Methanol and its 20.9 when I first start it up.
