Upper control arm #2943666
07/15/21 07:41 PM
07/15/21 07:41 PM
colorado
a12superbee Offline OP
colorado
Hey fellers, trying to rebuild the front of my '69 440 6 pack stupid bee, I ordered Moog control arm bushings K408.
The bushings are 1.25 dia on the small end but the hole in the control arm is only 1.57 ish.
What do I have wrong here, wrong parts in the box or my uppers were swapped along the way?
Anybody know the number for the bushing I do need?
Ball joint screwed in, I'm confused, wouldn't an a arm from a lower level 318 car use a smaller ball joint?
Thank guys.
I can't afford this. mark
Re: Upper control arm [Re: a12superbee] #2943707
07/15/21 08:31 PM
07/15/21 08:31 PM
Andrewh Offline
Andrewh  Offline
ball joints are the same for all b-bodies. doesn't matter what came in it.
bushings I can't answer, but someone should be along shortly.
Re: Upper control arm [Re: a12superbee] #2943769
07/15/21 10:46 PM
07/15/21 10:46 PM
AndyF Offline
AndyF  Offline
The bushings should be about 1.17 on the small end. No idea what your measurements are from. All '62 to '72 B body upper control arms use the same bushings.
Re: Upper control arm [Re: Andrewh] #2943770
07/15/21 10:51 PM
07/15/21 10:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A and B bodies (and then E-bodies) all used the same control arm bushings during these years (things may have changed with the isolated K-member B-bodies and things did change with the transverse torsion bar front ends).
Re: Upper control arm [Re: AndyF] #2943773
07/15/21 10:56 PM
07/15/21 10:56 PM
colorado
colorado
Thank you for that, the bushings I pressed out are 1.17
Perhaps the Moog boxes I received simply have the wrong parts in them, like c body or truck bushings.
Anyone have an opinion on the repop a arms?
Re: Upper control arm [Re: a12superbee] #2943782
07/16/21 12:31 AM
07/16/21 12:31 AM
A727Tflite Offline
A727Tflite  Offline
I installed a set, went right on.
They are made of thinner gauge material, I don’t think I would use them in autocross or something similar.
Drag car or normal street use I think they should be fine.
Re: Upper control arm [Re: A727Tflite] #2943791
07/16/21 01:49 AM
07/16/21 01:49 AM
colorado
colorado
Cool, thanks for the tip.
I figured they were thinner, I'll leave them as a last resort.
