Upper control arm
#2943666
07/15/21 07:41 PM
07/15/21 07:41 PM
Posts: 6,301 colorado
a12superbee
colorado
Hey fellers, trying to rebuild the front of my '69 440 6 pack stupid bee, I ordered Moog control arm bushings K408. The bushings are 1.25 dia on the small end but the hole in the control arm is only 1.57 ish. What do I have wrong here, wrong parts in the box or my uppers were swapped along the way? Anybody know the number for the bushing I do need? Ball joint screwed in, I'm confused, wouldn't an a arm from a lower level 318 car use a smaller ball joint?
Thank guys.
I can't afford this.
mark
Re: Upper control arm
[Re: AndyF]
#2943773
07/15/21 10:56 PM
07/15/21 10:56 PM
a12superbee
colorado
Thank you for that, the bushings I pressed out are 1.17 Perhaps the Moog boxes I received simply have the wrong parts in them, like c body or truck bushings. Anyone have an opinion on the repop a arms?
mark
[Re: a12superbee]
#2943782
07/16/21 12:31 AM
07/16/21 12:31 AM
Posts: 3,081 Michigan
A727Tflite
Thank you for that, the bushings I pressed out are 1.17 Perhaps the Moog boxes I received simply have the wrong parts in them, like c body or truck bushings. Anyone have an opinion on the repop a arms? I installed a set, went right on. They are made of thinner gauge material, I don’t think I would use them in autocross or something similar. Drag car or normal street use I think they should be fine.
[Re: A727Tflite]
#2943791
07/16/21 01:49 AM
07/16/21 01:49 AM
a12superbee
colorado
Cool, thanks for the tip. I figured they were thinner, I'll leave them as a last resort.
mark
