69 Charger trunk lid torsion bar adjustment #2942453
07/12/21 09:20 PM
07/12/21 09:20 PM
NH
N
NHCharger Offline OP
N
NH
The FSM directions seem rather vague, thinking I'm going to hurt myself. Checked you tube.
What is the process for adjusting them? Need more tension so the trunk lid stays up higher.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: 69 Charger trunk lid torsion bar adjustment [Re: NHCharger] #2942462
07/12/21 09:34 PM
07/12/21 09:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Have someone hold the lid fully open and you can use a small bar to unload it from the adjustment hole and move it to the next hole for more tension. Takes a little understanding and you need to be creative.
Re: 69 Charger trunk lid torsion bar adjustment [Re: NITROUSN] #2942836
07/13/21 11:24 PM
07/13/21 11:24 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This
Re: 69 Charger trunk lid torsion bar adjustment [Re: kentj340] #2943703
07/15/21 08:22 PM
07/15/21 08:22 PM
NH
N
N
NH
Thanks, got it. I was going about it backwards. Wife held the trunk lid wide open, I clamped my vice grips on the end that pushes against the trunk hinge and eased it out of the retaining slot that holds it against the trunk hinge, then backed off the pressure, moved the adjustment end down two notches, put the torsion bar back in place. done in two minutes. Took longer to climb in and out of the trunk.
Re: 69 Charger trunk lid torsion bar adjustment [Re: NHCharger] #2943741
07/15/21 09:52 PM
07/15/21 09:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
At least you got it figured out and were able to get out of the trunk. Jimmy Hoffa never got out.
