511 B Street on the dyno #2942332
07/12/21 01:32 PM
07/12/21 01:32 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Just finishing this project up and some of the parts were very slow to come in. This is just a basic 10.4 comp street build slated for a heavy '70 Charger with 3.55's and a 4spd. It's a 440 Source crank, Eagle H beam rods, Icon dished pistons, Comp street roller with 246 @ .050" .630" 110 LSA, Howards Hydraulic Roller lifters, Edelbrock 5090 cleaned up/VJ/Resurfaced, 383 Torker , Holley 950 XP. So far so good. Previous customer's engine was a 470 B with Maxwedge Pro-comps etc.... More horsepower but about 50lb/ft less at a much higher RPM. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 511 B Street on the dyno [Re: RAMM] #2942339
07/12/21 02:11 PM
07/12/21 02:11 PM
AndyF Offline
AndyF  Offline
Looks about right. The 512 low deck in my Duster made 603 @ 5900 with ported Mopar 452 aluminum heads and a 246@50 hyd roller cam. I used a Trick Flow intake rather than the Torker but everything else is pretty close to what you have there. Mine idles at 950 rpm with 16 inches of vacuum but pulls hard in every gear.
Re: 511 B Street on the dyno [Re: RAMM] #2942349
07/12/21 03:22 PM
07/12/21 03:22 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Wow That tourqe curve gna break stuff! The 470 made more?
Re: 511 B Street on the dyno [Re: pro451bee] #2942392
07/12/21 05:38 PM
07/12/21 05:38 PM
RAMM Offline OP
RAMM  Offline OP
Yeah the 470 made 650hp but at a much higher rpm. It wasn't really an ideal fit for a heavy B body. J.Rob
Re: 511 B Street on the dyno [Re: RAMM] #2942577
07/13/21 10:38 AM
07/13/21 10:38 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice work!
Re: 511 B Street on the dyno [Re: RAMM] #2942606
07/13/21 12:05 PM
07/13/21 12:05 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Nice. Man I wish I had dynoed my engine before it was in the car.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 511 B Street on the dyno [Re: RAMM] #2942608
07/13/21 12:18 PM
07/13/21 12:18 PM
Longer stroke, smaller intake ports = more torque up
Re: 511 B Street on the dyno [Re: Cab_Burge] #2942644
07/13/21 01:21 PM
07/13/21 01:21 PM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Wow a perfect build for a heavy car and a four speed!
Doing a 511ci (440) myself with Dash One heads for my 71 GTX, Auto and 8-3/4 axle.
My Moparmate bought a 470ci ex-Landy 400 motor that was in the 'Engine masters'
It made 700hp with 'new' back then 572-13 heads.
It was a screamer, but fell apart real quick lol...
The main-caps were the biggest set-back so we fitted program 'batwings' 4-bolt caps and all was good...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 511 B Street on the dyno [Re: Gtxxjon] #2942648
07/13/21 01:28 PM
07/13/21 01:28 PM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
My other Moparmate built a 512ci for his street Polara! fury
He lives in London Town and drive it most days in summer.
Completely original car with 3.23 gears and runs 13 dead in the quarter (in drive). drive
Crower street roller 0.550 lift
Best bit is the carb a 950 HP Holley that gets 17 to the gallon... drumhit
Imagine that engine in a Dart or Barracuda... chargerwork green
Re: 511 B Street on the dyno [Re: RAMM] #2943502
07/15/21 01:06 PM
07/15/21 01:06 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
That looks like an awsome street engine , suprized that torker manifold suports that much power , thiking about trying one out.
Re: 511 B Street on the dyno [Re: pro451bee] #2943700
07/15/21 08:18 PM
07/15/21 08:18 PM
Edlebrock Performer RPM are way better on the street and on a engine dyno test than the Torker, Torker 2 or the Tarantula intakes on pump gas stroker BB (RB and B motors) for street use up twocents
Re: 511 B Street on the dyno [Re: Cab_Burge] #2944399
07/17/21 09:11 PM
07/17/21 09:11 PM
Livonia,MI
1968fury Offline
1968fury  Offline
Livonia,MI
What rocker ratio was used. Seems like alot of lift for 246@50
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: 511 B Street on the dyno [Re: 1968fury] #2944570
07/18/21 02:33 PM
07/18/21 02:33 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
Very nice RAMM, Will make your customer happy, he better have a dana.
Re: 511 B Street on the dyno [Re: 1968fury] #2944770
07/19/21 09:16 AM
07/19/21 09:16 AM
RAMM Offline OP
RAMM  Offline OP
You're right it is only .570" lift now with the PRW 1.5's. It used to be .630" ish. J.Rob
