resealing a BG 280 fuel pump #2940927
07/07/21 06:59 PM
07/07/21 06:59 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Has anybody replaced the seals in a 280 BG pump. The kits available. Looks like its leaking from the shaft seal. I took it apart and cleaned it and lubed the shaft. Still leaks. I have to wait a week for the parts. Monster Mopar is getting closer.
Doug
Re: resealing a BG 280 fuel pump [Re: dvw] #2940946
07/07/21 08:07 PM
07/07/21 08:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Had to reseal every BG pump that I owned at one time or another.
Re: resealing a BG 280 fuel pump [Re: dvw] #2940968
07/07/21 09:03 PM
07/07/21 09:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Doug
This guy has always gotten my stuff to me pretty quick
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: resealing a BG 280 fuel pump [Re: pittsburghracer] #2940969
07/07/21 09:04 PM
07/07/21 09:04 PM
PA.
"Little"John
"Little"John
PA.
He has different kits so look around
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: resealing a BG 280 fuel pump [Re: pittsburghracer] #2940993
07/07/21 10:14 PM
07/07/21 10:14 PM
PA.
"Little"John
"Little"John
PA.
Amazon is advertising it as the same kit as the bg400. If you were closer I have a couple kits. I always order extras to take to the track incase I would have to do a quick rebuild
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: resealing a BG 280 fuel pump [Re: pittsburghracer] #2940994
07/07/21 10:17 PM
07/07/21 10:17 PM
PA.
"Little"John
"Little"John
PA.
B863D6AD-0E87-4F30-BE13-BBCE0F88F878.jpeg0FEC53CB-2C2F-4746-8BEF-72874B5E4C25.jpeg9F82E2F4-7AFF-4280-AE8D-F098E4457799.jpeg
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: resealing a BG 280 fuel pump [Re: pittsburghracer] #2941013
07/07/21 11:19 PM
07/07/21 11:19 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
That's the kit I ordered. Got the distributor rebuilt and the supercharger bolted back on. Carbs, fan and little wiring tomorrow. Getting close to getting it back out. It's amazing how well its all cleaned up after setting for 10 years.
Doug
Re: resealing a BG 280 fuel pump [Re: dvw] #2941145
07/08/21 11:06 AM
07/08/21 11:06 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You can get just the seal. There is a NOK number on it. I used to get them from my local bearing and seal supplier for like 2 or 3 bucks a seal. Most all the time the o-rings are still good.
