Brodix B1 heads #2940494
07/06/21 12:36 PM
07/06/21 12:36 PM
Isle of Sheeps
Gtxxjon Offline OP
Gtxxjon  Offline OP
Isle of Sheeps
Anyone run the small block B1 Brodix heads?
I got a set off a guy who said you can run Chevrolet rockers, think it’ says that on their site?
But the only rockers that will work is Jesel I believe???
Thanx for any advice, gtxxjon
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Brodie B1 heads [Re: Gtxxjon] #2940564
07/06/21 04:38 PM
07/06/21 04:38 PM
Ask Brodix first twocents scope
Re: Brodie B1 heads [Re: Gtxxjon] #2940608
07/06/21 06:41 PM
07/06/21 06:41 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Brodix state in their web site;
[/b]If using an R Block that oils through the pushrods, small block Chevrolet rockers may be used. Special guide plates may have to be fabricated to use the Chevrolet rockers.
If using a standard 340 or 360 block, standard adjustable Chrysler rocker arms may be used with special B1 stands[b]
Re: Brodie B1 heads [Re: mopar_mark] #2941069
07/08/21 04:14 AM
07/08/21 04:14 AM
Isle of Sheeps
Gtxxjon Offline OP
Gtxxjon  Offline OP
Isle of Sheeps
Thanx Mopar Mark,
Hope you are keeping well.
I see Jimbo is selling his Coronet after all these years.
Yes I saw the literature from the Brodix site about Chev rockers with the R block.
But don't understand why you can't use them with the 340/360 block 59 degree lifters?
How does the 48 degree R block change the pushrod to rocker geometry?
I need to set up my Brodix heads on a 340 block and see 'whats-what' methinks?
If not, I will be using my Indy dash ones on the 512 instead to run in the 'UK Superstocks'.
Need to get my 71 Duster into the MID NINES on 10 inch slicks...
Re: Brodie B1 heads [Re: Gtxxjon] #2941181
07/08/21 01:13 PM
07/08/21 01:13 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Hi,
Yes, all good thanks.
Jimbo has now changed his mind & keeping the Coronet, his new set of B1 Originals having a big influence on the decision wink
I don’t know enough about small blocks to comment. I think I would do the same & see what the heads are like in the block & go from there
Re: Brodie B1 heads [Re: mopar_mark] #2941189
07/08/21 01:44 PM
07/08/21 01:44 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Do you have oem like rocker stands currently on the heads.
This link has a confusing description.
https://www.ebay.com/itm/BRODIX-B1B...YLINDER-HEADS-BARE-3180000-/290579109412
STOP POTATO HATE!
Re: Brodie B1 heads [Re: Mr PotatoHead] #2941433
07/09/21 04:26 AM
07/09/21 04:26 AM
Isle of Sheeps
Gtxxjon Offline OP
Gtxxjon  Offline OP
Isle of Sheeps
Where would we be without potatoes?
Spoke to Mr. Shannon about the Chev rocker gear and he just laughed?
The heads I have are milled-off for Jesel rockers and or Chev small-block...
Found some pics on A-bods with the Chev 'rockers and posts' 'on-top', looks OK to me!
The exhausts are straight and the inlets are approx .250 offset like W2's are.
Very confusing with the S/B Chev stuff if they are straight or offset too??? shruggy
Re: Brodie B1 heads [Re: Gtxxjon] #2941455
07/09/21 09:23 AM
07/09/21 09:23 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Standard Chevy rockers are no offset, they make offset ones though.
