Warranty statement
#2939571
07/03/21 08:35 PM
07/03/21 08:35 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
What are your opinions on this warranty disclaimer from ATK Performance on 440 crate engine?
Warranty:
The engine will have our standard 2 year warranty with the exception of rear main seal/oil pan leaks. Unfortunately this engine block was prone to leaks from Mopar and often there is no fix for it due to bad tooling from Mopar. A full break down of the warranty can be found on our ATK High Performance website.
Facts are stubborn things.
Re: Warranty statement
[Re: TJP]
#2939819
07/04/21 12:34 PM
07/04/21 12:34 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
That was the feeling I got too but I wasn't sure. Real turnoff. Thanks.
[Re: larrymopar360]
#2939884
07/04/21 02:48 PM
07/04/21 02:48 PM
Posts: 4,757 Star Idaho
67vertman
Star Idaho
That is sad! I would pass on an engine builder who had this in their warranty statement. My 440 has more than 7 years on its rebuild and it's not leaking.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 5thAve]
#2939961
07/04/21 07:46 PM
07/04/21 07:46 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Sort of sounds like they are using junk gaskets or other parts if they are having high number of problems. Yeah a disclaimer of "be prepared for problems" isn't comforting.
[Re: larrymopar360]
#2939968
07/04/21 08:20 PM
07/04/21 08:20 PM
Posts: 5,818 ohio
ruderunner
ohio
I did my first one 25 years ago, it doesn't leak.
Sorry but that's a bit much to accept from a "professional " rebuilder.
Angry white pureblood male
[Re: ruderunner]
#2940004
07/04/21 11:08 PM
07/04/21 11:08 PM
Posts: 6,252 nowhere
Sniper
nowhere
Sorry but that's a bit much to accept from a "professional " rebuilder. 25 years ago I could run the mile and a half in 9 minutes in full gear. 25 years and a triple bypass later I am lucky to do it in a 20 minutes in gym shorts. I'm 25 years older, 25 years more wore out but at least I didn't have 25 years more of "mechanics" doing who knows what to me.
[Re: Sniper]
#2940043
07/05/21 06:47 AM
07/05/21 06:47 AM
Posts: 5,818 ohio
ruderunner
ohio
25 years later you've probably developed a few leaks of your own. But, it's not rocket science to put a rear seal in a big block.
[Re: Sniper]
#2940081
07/05/21 10:19 AM
07/05/21 10:19 AM
Posts: 15,359 Omaha Ne
TJP
Omaha Ne
Sorry but that's a bit much to accept from a "professional " rebuilder. 25 years ago I could run the mile and a half in 9 minutes in full gear. 25 years and a triple bypass later I am lucky to do it in a 20 minutes in gym shorts. I'm 25 years older, 25 years more wore out but at least I didn't have 25 years more of "mechanics" doing who knows what to me. Well Dr.'s are typically referred to as "practicing" Does ATK claim the same?? would seem so
