Re: Richmond 5-spd vs 6-spd ROD
[Re: hemienvy]
#2939594
07/03/21 09:03 PM
07/03/21 09:03 PM
Posts: 952 Central Michigan
nuthinbutmopar
Central Michigan
These anecdotes, what they are suggesting to me is that these factory transmissions were not "properly engineered". They're engineered perfectly for their purpose: to maximize fuel economy on the EPA drive cycle. It's the same reason we've got 8-9-10 speed automatics instead of 3 speeds. Go back to the Corvette that had the solenoid that kicked the 1-2 shift to fourth gear in very specific circumstances, those being exactly how the EPA fuel economy test is run. VW took it a step too far when they changed the engine parameters when the computer sensed the EPA cycle in progress. The fact that nobody in the real world drives the way the drive cycle works means they seem crazy to those us that live and drive in the real world.
[Re: moparx]
#2939597
07/03/21 09:08 PM
07/03/21 09:08 PM
Posts: 15,483 Omaha Ne
TJP
Omaha Ne
[Re: AndyF]
#2939679
07/04/21 01:45 AM
07/04/21 01:45 AM
Posts: 27,474 So Cal
autoxcuda
So Cal
I bought a Doug Nash 5 speed for my Coronet back in 1988 so I was one of the first to have a 5 speed in a street driver Mopar. How would you rate or comment the shifting compared to: -T56 -A833
[Re: AndyF]
#2939767
07/04/21 11:22 AM
07/04/21 11:22 AM
autoxcuda
So Cal
My Doug Nash is very clunky. Shifts like a tractor. Thank you. Always appreciate your input and help. What shifter mechanism do you have? I have a Long Shifter that came with the Richmond I got. Does that make any difference? Or is that the shifter everyone uses? I got mine in a parts deal and it’s all still new in the box.
[Re: hemienvy]
#2939770
07/04/21 11:24 AM
07/04/21 11:24 AM
TJP
Omaha Ne
Well I do appreciate the input but this is not going where I hoped it would.
I was hoping to find people who have driven Richmond 5 or 6 speeds, in whichever kind of street car.
The gear ratios is not an issue at all.
I do recognize that these trannies don't easily fit in A- or B- bodies, but that's still not the topic.
I'm interested in shift quality and hi-RPM shift capability.
How high can you reliably shift a synchro A833 ? I think they are the same rings used in the Richmond.
I have driven both in a multitude of different cars. The normal shifting is fine in both, little experience with the high RPM part (I don't abuse customers cars) but the few I have had to shifted fine at 5.5-6K. Again, these were very limited experiences and only shifts between 1st and 2nd. In every case 6th gear was IMO useless. I have shifted plenty of 833's at 6500, usually at WOT fanning the clutch never having an issue I might also comment that in all cases with high RPM shifts we had installed the trans AND DIALED IN the bellhousing / scatter shield
[Re: AndyF]
#2939773
07/04/21 11:25 AM
07/04/21 11:25 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
m y friend installed a richmond 5 speed in a 71 challenger convert with a 604 hemi about 1998. it was a feature car in Mopar collectors guide in may 2000. we had to do a fair amount of cutting and welding ti install it.
i have a T56 magnum xl 6 speed trans in my supercharged 800rwhp 08 bullitt mustang. the shifting differences are night and day between the 2.
perception is 90% of reality
[Re: autoxcuda]
#2939849
07/04/21 01:30 PM
07/04/21 01:30 PM
Posts: 31,068 Oregon
AndyF
My Doug Nash is very clunky. Shifts like a tractor. Thank you. Always appreciate your input and help. What shifter mechanism do you have? I have a Long Shifter that came with the Richmond I got. Does that make any difference? Or is that the shifter everyone uses? I got mine in a parts deal and it’s all still new in the box. I have the Hurst shifter with mine. I've known other guys with Doug Nash (or Richmond) 5 speeds that also say they are very clunky. From what I've heard the issue is that Doug Nash used synchros that were too small for the weight of the 5 speed main cluster. Evidently there are people who now know how to fix that problem but I've never tried to have mine fixed. I do have a buddy who got rid of his Richmond 5 speed and replaced it with a T56 based 6 speed and he says the difference in shifting is amazing. He used to tell me that his Richmond shifted okay but now he knows that it didn't. He was just used to it. I don't know if Richmond ever fixed the clunky shifting design that they inherited from Doug Nash. I doubt that they would tell you on the phone so a person would need to speak to an independent transmission expert. The little bit of research I did on the subject in the past led me to believer that Richmond never really fixed the issue.
