Page 1 of 3 1 2 3
Trans Fluid Leak Down Speedo Cable #2938831
07/01/21 07:39 PM
07/01/21 07:39 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
The speedo cable nut is fairly tight but I have fluid leaking and running down the speedo cable then dripping onto the exhaust collector. How do I stop the leak?
70 727
Re: Trans Fluid Leak Down Speedo Cable [Re: YO7_A66] #2938835
07/01/21 07:57 PM
07/01/21 07:57 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Is the O-Ring on the speedo gear shaft good and is the O-Ring on the gear housing good?
Re: Trans Fluid Leak Down Speedo Cable [Re: SNK-EYZ] #2938838
07/01/21 08:08 PM
07/01/21 08:08 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I will check both of them in the morning. I’m letting it cool down before I pull it off.
Thanks!
Re: Trans Fluid Leak Down Speedo Cable [Re: SNK-EYZ] #2938847
07/01/21 08:37 PM
07/01/21 08:37 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I couldn’t wait😀.
I pulled it off and a broken o-ring fell out. Got it replaced and will test it this weekend.
Thank you!
Re: Trans Fluid Leak Down Speedo Cable [Re: YO7_A66] #2938851
07/01/21 09:00 PM
07/01/21 09:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
be aware there is an inner seal for the speedometer gear, it is held in with a spring clip. The lip faces inward. there is also an outer O-ring for the housing. beer
Re: Trans Fluid Leak Down Speedo Cable [Re: TJP] #2938863
07/01/21 09:37 PM
07/01/21 09:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree scope
Re: Trans Fluid Leak Down Speedo Cable [Re: Cab_Burge] #2938865
07/01/21 09:47 PM
07/01/21 09:47 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
The leak appears to be coming from the cable/nut area. Then the fluid travels down the cable. I put two different diameter o-rings inside of the nut to try and seal it up.
The speedo housing is completely dry.
Thank you!
Re: Trans Fluid Leak Down Speedo Cable [Re: YO7_A66] #2938956
07/02/21 09:27 AM
07/02/21 09:27 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Thank you!
You need to remove the speedometer adapter from the transmission. Then slide the gear out and look into the bore of the housing. You will see a wire retaining ring and a small v-seal. That is the source of your leak.
Re: Trans Fluid Leak Down Speedo Cable [Re: NITROUSN] #2939017
07/02/21 01:21 PM
07/02/21 01:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Thank you!
This ....
Re: Trans Fluid Leak Down Speedo Cable [Re: JohnRR] #2939019
07/02/21 01:35 PM
07/02/21 01:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of the seal and wire retaining ring.
Re: Trans Fluid Leak Down Speedo Cable [Re: John_Kunkel] #2939026
07/02/21 01:52 PM
07/02/21 01:52 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thanks guys!! I was having trouble visualizing where that seal was located👍
Re: Trans Fluid Leak Down Speedo Cable [Re: YO7_A66] #2939030
07/02/21 02:00 PM
07/02/21 02:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Seal part number is 2538588.
Re: Trans Fluid Leak Down Speedo Cable [Re: John_Kunkel] #2939046
07/02/21 02:44 PM
07/02/21 02:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
ATP part number is SO13, might be easier to locally source one of those.
If you, or someone else, needs the bog oring around the adapter that is ATP TO34
Re: Trans Fluid Leak Down Speedo Cable [Re: Sniper] #2939090
07/02/21 06:21 PM
07/02/21 06:21 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you for the part numbers!!
Re: Trans Fluid Leak Down Speedo Cable [Re: YO7_A66] #2939118
07/02/21 07:10 PM
07/02/21 07:10 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Parking on a slant toward the front of trans helps too. Don't have a lot of fluid loss.
Facts are stubborn things.
Re: Trans Fluid Leak Down Speedo Cable [Re: larrymopar360] #2939179
07/02/21 10:07 PM
07/02/21 10:07 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I just bought a seal kit from Eberg a couple weeks ago:
https://www.ebay.com/itm/324510752336
Re: Trans Fluid Leak Down Speedo Cable [Re: Montclaire] #2939284
07/03/21 11:28 AM
07/03/21 11:28 AM
BDW Offline
BDW  Offline
Yikes! $26 for shipping! Won't those parts fit in an envelope?
Re: Trans Fluid Leak Down Speedo Cable [Re: BDW] #2939294
07/03/21 11:46 AM
07/03/21 11:46 AM
moparx Offline
moparx  Offline
give me a day or so to look, i "might" have some extra of those seals in my parts cabinet.
if i do, i'll send them to the OP, gratis.
beer
Re: Trans Fluid Leak Down Speedo Cable [Re: moparx] #2939354
07/03/21 12:59 PM
07/03/21 12:59 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you for looking!
Re: Trans Fluid Leak Down Speedo Cable [Re: BDW] #2939372
07/03/21 01:11 PM
07/03/21 01:11 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not sure where you are getting $26 for shipping, listing shows $4.30 for shipping.
Basically, $15 delivered. Or you can order the stuff using the ATP numbers provided at a local store. For a crap ton less.
Advance shows a 5 pack of the seals for $2.99, big oring is $2.19 for a 5 pack.
Page 1 of 3 1 2 3
