Trans Fluid Leak Down Speedo Cable
#2938831
07/01/21 07:39 PM
07/01/21 07:39 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
The speedo cable nut is fairly tight but I have fluid leaking and running down the speedo cable then dripping onto the exhaust collector. How do I stop the leak?
70 727
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Trans Fluid Leak Down Speedo Cable
[Re: YO7_A66]
#2938835
07/01/21 07:57 PM
07/01/21 07:57 PM
Posts: 10,167 A Red State
SNK-EYZ
A Red State
Is the O-Ring on the speedo gear shaft good and is the O-Ring on the gear housing good?
[Re: SNK-EYZ]
#2938838
07/01/21 08:08 PM
07/01/21 08:08 PM
YO7_A66
Indiana
I will check both of them in the morning. I’m letting it cool down before I pull it off. Thanks!
[Re: SNK-EYZ]
#2938847
07/01/21 08:37 PM
07/01/21 08:37 PM
YO7_A66
Indiana
I couldn’t wait😀. I pulled it off and a broken o-ring fell out. Got it replaced and will test it this weekend. Thank you!
[Re: Cab_Burge]
#2938865
07/01/21 09:47 PM
07/01/21 09:47 PM
YO7_A66
Indiana
The leak appears to be coming from the cable/nut area. Then the fluid travels down the cable. I put two different diameter o-rings inside of the nut to try and seal it up.
The speedo housing is completely dry.
Thank you!
[Re: YO7_A66]
#2938956
07/02/21 09:27 AM
07/02/21 09:27 AM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Thank you! You need to remove the speedometer adapter from the transmission. Then slide the gear out and look into the bore of the housing. You will see a wire retaining ring and a small v-seal. That is the source of your leak.
[Re: NITROUSN]
#2939017
07/02/21 01:21 PM
07/02/21 01:21 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Thank you! You need to remove the speedometer adapter from the transmission. Then slide the gear out and look into the bore of the housing. You will see a wire retaining ring and a small v-seal. That is the source of your leak. This ....
[Re: JohnRR]
#2939019
07/02/21 01:35 PM
07/02/21 01:35 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's a pic of the seal and wire retaining ring.
[Re: John_Kunkel]
#2939026
07/02/21 01:52 PM
07/02/21 01:52 PM
YO7_A66
Indiana
Thanks guys!! I was having trouble visualizing where that seal was located👍
[Re: YO7_A66]
#2939030
07/02/21 02:00 PM
07/02/21 02:00 PM
John_Kunkel
Rio Linda, CA
Seal part number is 2538588.
[Re: John_Kunkel]
#2939046
07/02/21 02:44 PM
07/02/21 02:44 PM
Posts: 6,325 nowhere
Sniper
nowhere
ATP part number is SO13, might be easier to locally source one of those.
If you, or someone else, needs the bog oring around the adapter that is ATP TO34
[Re: Sniper]
#2939090
07/02/21 06:21 PM
07/02/21 06:21 PM
YO7_A66
Indiana
Thank you for the part numbers!!
[Re: YO7_A66]
#2939118
07/02/21 07:10 PM
07/02/21 07:10 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Parking on a slant toward the front of trans helps too. Don't have a lot of fluid loss.
Facts are stubborn things.
[Re: BDW]
#2939372
07/03/21 01:11 PM
07/03/21 01:11 PM
Sniper
nowhere
Yikes! $26 for shipping! Won't those parts fit in an envelope? Not sure where you are getting $26 for shipping, listing shows $4.30 for shipping. Basically, $15 delivered. Or you can order the stuff using the ATP numbers provided at a local store. For a crap ton less. Advance shows a 5 pack of the seals for $2.99, big oring is $2.19 for a 5 pack.
