Milodon Oil Pan 31161 or 31151 #2938658
07/01/21 10:31 AM
07/01/21 10:31 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Has anyone used one of these big block oil pans?
One is just 1" deeper than the other (7 qts vs 9 qts).
The description says, "These pans have a full-length windage tray and double trap doors to provide a positive oil control system."
And for up to 4.750" stroke.
Opinions?
I am looking at oil pans for my Daytona (chassis car) and new 572 CID B1 engine. (4.5" stroke).
Summit LInk
Re: Milodon Oil Pan 31161 or 31151 [Re: 440Jim] #2938662
07/01/21 10:46 AM
07/01/21 10:46 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have one in my Road Runner.
69 GTX 68 Road Runner
Re: Milodon Oil Pan 31161 or 31151 [Re: JERICOGTX] #2938663
07/01/21 10:47 AM
07/01/21 10:47 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run one
Re: Milodon Oil Pan 31161 or 31151 [Re: 440Jim] #2938682
07/01/21 11:33 AM
07/01/21 11:33 AM
PA
Harry's Taxi 2 Offline
PA
I run the 9 qt. one (with 7qts.).....took the tray out and replaced it with a screen and mazzolini crank scraper. 9.0's and no oil pressure fluctuations on data recorder.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Milodon Oil Pan 31161 or 31151 [Re: Harry's Taxi 2] #2938686
07/01/21 11:45 AM
07/01/21 11:45 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I have put one on my aluminum rod 493 and dual line swivel pickup. Have not run it yet. I was kind of skeptical looking at the tray in it,regarding drainback capabilities. Called Milodon tech line and they said it was capable as built and didn't recommend any modifications. I guess I will find out. Hope they are right. I am going to start out using their recommended capacity. Bill
Re: Milodon Oil Pan 31161 or 31151 [Re: lancer493] #2938689
07/01/21 11:52 AM
07/01/21 11:52 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Anyone have a picture of what it looks like under the "windage tray"?
Does it actually have trap doors for oil control? Or is that just boiler plate from the catalog on Milodon oil pans in general?
I have heard good things about screen type windage trays.
Re: Milodon Oil Pan 31161 or 31151 [Re: 440Jim] #2938722
07/01/21 01:20 PM
07/01/21 01:20 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I think it has 3 trap doors. I modified mine for a big single pickup. No oil issues on my data log.
Re: Milodon Oil Pan 31161 or 31151 [Re: FastmOp] #2938724
07/01/21 01:26 PM
07/01/21 01:26 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i have a 31150 pan that someone gave me. Its now not availible?? but looks exactly like the one above.
Not to hijack, but can this pan be used with a static pickup?
....BAD A$$ STREET CAR.....
Re: Milodon Oil Pan 31161 or 31151 [Re: n20mstr] #2938734
07/01/21 01:53 PM
07/01/21 01:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I had to cut, grind, and weld on mine. But I have an oiling setup that's been good to me so I use it in everything. The big square single pickup . Single external line.
Re: Milodon Oil Pan 31161 or 31151 [Re: FastmOp] #2938848
07/01/21 08:38 PM
07/01/21 08:38 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Good to hear.
IMO, for my application, I think a single AN-12 external line with a static pick-up at the back of a pan with that slant toward the back should be good.
A trap door or two for deceleration to work with the slant back sounds like a workable solution.
Re: Milodon Oil Pan 31161 or 31151 [Re: 440Jim] #2938915
07/02/21 06:53 AM
07/02/21 06:53 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
On my car the pan bottom is about level. Tube chassi Avenger. . Ka-Blue-E
Re: Milodon Oil Pan 31161 or 31151 [Re: FastmOp] #2939000
07/02/21 12:10 PM
07/02/21 12:10 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Jim, here are pictures below the tray. It has 2 separate swinging trap doors. This is a 31151, it's a spare that I have. I have the 31161 on my car currently with a dual line swinging pick up.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Milodon Oil Pan 31161 or 31151 [Re: WadeMetzinger] #2939004
07/02/21 12:22 PM
07/02/21 12:22 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I run the 31151 with dual lines. My only issue is a small leak at the lines that I can’t seem to get to fully seal.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Milodon Oil Pan 31161 or 31151 [Re: WadeMetzinger] #2939020
07/02/21 01:37 PM
07/02/21 01:37 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Wade, thanks for the inside pics. up
I like that design. The bolt-in windage tray doesn't look like anything special, but the side deflector is a good thought, IMO
Re: Milodon Oil Pan 31161 or 31151 [Re: 440Jim] #2939028
07/02/21 01:54 PM
07/02/21 01:54 PM
AndyF Offline
AndyF  Offline
I used the Moroso dragster pan with a single #20 AN line on one of my dyno engines. Also used an external belt driven oil pump/vacuum pump combo. Not sure if that would fit in your car or not but it was a nice setup. The belt driven oil pump has some advantages over a gear driven pump.
Re: Milodon Oil Pan 31161 or 31151 [Re: AndyF] #2939029
07/02/21 01:56 PM
07/02/21 01:56 PM
AndyF Offline
AndyF  Offline
Here is the inside of the Moroso pan.
