5.7 swap in a 92 D150
#2935312
06/21/21 02:25 PM
06/21/21 02:25 PM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
I am considering doing a 5.7 Hemi swap into my 92 D150 It already has a 518 trans I know I can use it with a different flywheel and that Holley makes a kit for the swap has anybody done this swap ? pros and cons ? Thanks
Re: 5.7 swap in a 92 D150
[Re: BlwnCrcab]
#2937324
06/27/21 02:19 PM
06/27/21 02:19 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Havent done it but cant see any reason not to . Better motor... good luck with the project. I believe there are pre emissions wiring and processors available.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Fat_Mike]
#2937848
06/28/21 10:38 PM
06/28/21 10:38 PM
Posts: 10,586 Freeport IL USA
poorboy
Freeport IL USA
Yep, I would think the Gen 3 section would offer more info. We installed a 5.7 into a 57 Dodge station wagon, but we used the transmission that was attached to the motor, and we bought a stand alone wire harness from www.hotwireauto.com to make it work with the 5.7 EFI and electronic trans. That set up has been working great for over 4 years now. You are not planning on doing what we did, so our info won't help you much.
[Re: 11secdart]
#2938859
07/01/21 09:24 PM
07/01/21 09:24 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
The con is your 518 transmission. I wouldn't waste one second trying to make that turd work with a Gen 3. Take the 545rfe or 8 speed that comes with the Gen 3 and never look back. (Grab every inch of wire and computers from your donor vehicle while you are at it. ) I can't remember is your truck has the 318 or 360? If 318, maybe look at a 360 Magnum like "The Gas Tap" on Youtube has........
Mo' Farts
Moderated by "tbagger".
[Re: 11secdart]
#2939001
07/02/21 12:18 PM
07/02/21 12:18 PM
Posts: 672 Wichita, KS
tmef
Wichita, KS
I belong to a very good group on Facebook called Dodge Truck Hemi Swap. You may want to check it out. Lots of experienced info.
[Re: tmef]
#3014878
02/13/22 12:42 AM
02/13/22 12:42 AM
Posts: 1,967 ID/MT
Cheeto
ID/MT
DIYHemi.com I believe they did a swap in that year range of truck.
Cheeto It's not perfect. It's not correct. It's not yours!
