My 2004 1500 Ram 5.7 died #2936481
06/24/21 05:47 PM
06/24/21 05:47 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
It starts and runs but I can not control the engine speed and then it dies again, it will start but does the same thing over. What do I look for? Thanks.
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2936487
06/24/21 06:02 PM
06/24/21 06:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Check engine light on? Pull the codes.
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2936493
06/24/21 06:11 PM
06/24/21 06:11 PM
GMP440 Offline
GMP440  Offline
Check the wire harness plug connections going to the computer to make sure there is no corrosion ,frayed wires or loose prongs. Had this happen on a 97 Buick Regal LS. Engine would be idling then quit. Spent some time trouble shooting the problem.
Found that wiring at plug going into the ecm, wasn't making a perfect connection at the plug.
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2936501
06/24/21 06:40 PM
06/24/21 06:40 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
Do you mean it idles for a moment then dies? Or that it will idle until you try to open the throttle? Or that the rpms are all over and then it dies?
I was driving my 2004 Durango down the street, slowed to turn left at a light and it coughed and stalled. I coasted around the turn, popped it in neutral and cranked it back up but it was running rough and smoking under the hood. The big and small ends of #6 rod got divorced, and the remainder of the big end windowed both sides of the block above the pan rail. Still ran and didn't leak a drop of coolant...
First step on an '04 should be to check for codes.
Re: My 2004 1500 Ram 5.7 died [Re: nuthinbutmopar] #2936507
06/24/21 06:58 PM
06/24/21 06:58 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Moments ago I tried to start it but it will not start.
Re: My 2004 1500 Ram 5.7 died [Re: nuthinbutmopar] #2936526
06/24/21 07:59 PM
06/24/21 07:59 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
In the case of your 04 Durango, had it been raining a lot right before it did that?
The 2004 to 2006 Durango's have a problem that after they get about 100k+ on them that the intake o-rings/gaskets don't seal properly and the water comes down off the cowl and drops right on the intake.
It seeps past the intake o-rings and part way fills the cylinder and it hydraulic locks it and snaps the powder forged connecting rods.
It's a common problem on them if you do an internet search.
I bought a really nice 2004 Durango Limited with a rod through the block that idled smooth and ran okay with one rod blown through the block.
I engine swapped it and it's now the wife's daily driver.
Re: My 2004 1500 Ram 5.7 died [Re: NITROUSN] #2936527
06/24/21 07:59 PM
06/24/21 07:59 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
This.
Check for DTC codes.
Re: My 2004 1500 Ram 5.7 died [Re: SNK-EYZ] #2936724
06/25/21 03:33 PM
06/25/21 03:33 PM
Central Michigan
N
N
Central Michigan
Heck, that was 2015 and I don't remember. I swapped the in a used motor and ran it another 80k before the frame rotted out above the trailer hitch last year...
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2936854
06/26/21 01:17 AM
06/26/21 01:17 AM
IL us
I
ink Offline
ink  Offline
I
IL us
did you try cleaning the throttle body ???
Re: My 2004 1500 Ram 5.7 died [Re: ink] #2936887
06/26/21 09:56 AM
06/26/21 09:56 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Sounds like a TPS, Throttle Position Sensor. On another note, my buddy's Ram wouldn't start and he had never changed the spark plugs, it gave similar symptoms, it would start and die then he did that and it fired right up... work
JB Rhinehart, Realist
A-Body's RULE!
Re: My 2004 1500 Ram 5.7 died [Re: Rhinodart] #2936924
06/26/21 11:13 AM
06/26/21 11:13 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Till he runs the codes all anyone is doing is guessing.
Re: My 2004 1500 Ram 5.7 died [Re: Sniper] #2937109
06/26/21 09:04 PM
06/26/21 09:04 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
This is going to sound out there, but have the battery tested. It may have enough to crank and start, but the voltage can drop low enough to cause the ecm to re-set. I've seen it before. Corroded terminals, or anything that can cause a voltage drop will cause the same thing. Good luck wave
Re: My 2004 1500 Ram 5.7 died [Re: Skeptic] #2937309
06/27/21 01:39 PM
06/27/21 01:39 PM
moparx Offline
moparx  Offline
wiring issues of all kinds will test your patience, and make you go bald !
the bad part of this is, the issue could be anywhere, under the hood or in the cab.
as has been said, a scan is the first thing to do, then you will go from there.
please keep us up to date as to your progress.
beer
Re: My 2004 1500 Ram 5.7 died [Re: Skeptic] #2937509
06/27/21 11:26 PM
06/27/21 11:26 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This is true.
In 2006 when I was shopping for a new truck, I saw a nice new one on a lot where it sat long enough to let the battery go flat. They jump started it but it ran rough and would barely move.
Friday, I retrieved a long dormant 2004 Toyota. I had to jump start it. I had no spare batteries around to swap in so I jump started and drove it. After 3 miles, the gauges started flickering and the engine stalled. Subsequent restarts were met with a gas pedal that now does nothing. The code reader determined a dead throttle position sensor. I suspect that running it with the alternator providing all the power somehow damaged the electronic speed sensor in the gas pedal assembly.
Re: My 2004 1500 Ram 5.7 died [Re: Kern Dog] #2937518
06/28/21 12:35 AM
06/28/21 12:35 AM
Boise
Moparteacher Offline
Boise
This is true.
I suspect it's in limp mode until you replace the battery and clear codes. Referring to the Toyota.
No electrical diagnosis, including driveability, codes, etc., starts until the vehicle has a battery that has a SOC of 75% or better and a properly operating charging system. In fact, the charging system should not be diagnosed until there's a good battery installed. Always, always, always start with the battery before following any electrical/electronic pinpoint testing. Without a proper battery analysis you're wasting time effort and money. You're battery analysis includes cables and connections, same for charging system.
Re: My 2004 1500 Ram 5.7 died [Re: Moparteacher] #2937710
06/28/21 04:18 PM
06/28/21 04:18 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
OK, I'm back from my little trip. How do I run the codes? Does this need to be done by a qualified mechanic?
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2937736
06/28/21 05:13 PM
06/28/21 05:13 PM
BDW Online content
BDW  Online Content
Go to Auto Zone , they will do it for free
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2937740
06/28/21 05:25 PM
06/28/21 05:25 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Turn key on and off three times, ending in on. The codes will show in the odometer area.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: My 2004 1500 Ram 5.7 died [Re: Prodart440] #2937744
06/28/21 05:34 PM
06/28/21 05:34 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks, I'll give that a try, it's not driveable the way it is.
Re: My 2004 1500 Ram 5.7 died [Re: MO_PA] #2937750
06/28/21 05:50 PM
06/28/21 05:50 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I did the ignition switch on/off, the engine light came on as well as the electronic throttle control icon.
