Re: Getting closer !
[Re: mopar dave]
#2936933
06/26/21 11:26 AM
06/26/21 11:26 AM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Looks good. I haven't been following, what cubic inch, compression and cam did you go with? 499 13.4-1 Bullet cam 649/620 lift 1.6 rockers
[Re: mopar dave]
#2936978
06/26/21 01:11 PM
06/26/21 01:11 PM
VernMotor
Mt.Vernon ,Ohio
Nice. I'm guessing a 270ish at 50? That should make some steam (700hp+). Trick flow 270 heads.. Indy intake . I don't know I was thinking 650 maybe.
[Re: VernMotor]
#2937377
06/27/21 05:36 PM
06/27/21 05:36 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Nice. I'm guessing a 270ish at 50? That should make some steam (700hp+). Trick flow 270 heads.. Indy intake . I don't know I was thinking 650 maybe. Wallace estimates mine @ 650/670ish . With your bigger comp, race gas ? , you should be a bit more . Stock block ? Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2937455
06/27/21 08:59 PM
06/27/21 08:59 PM
VernMotor
Mt.Vernon ,Ohio
Nice. I'm guessing a 270ish at 50? That should make some steam (700hp+). Trick flow 270 heads.. Indy intake . I don't know I was thinking 650 maybe. Wallace estimates mine @ 650/670ish . With your bigger comp, race gas ? , you should be a bit more . Stock block ? Tex Stock block billet main caps - E-85
[Re: VernMotor]
#2937533
06/28/21 03:26 AM
06/28/21 03:26 AM
tex013
Sydney,Australia
Getting close to limit . Good luck
Tex
[Re: tex013]
#2937552
06/28/21 08:11 AM
06/28/21 08:11 AM
Posts: 10,032 MN
JERICOGTX
MN
Is that a Moroso pressure relief valve?
Looks good.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2937599
06/28/21 11:24 AM
06/28/21 11:24 AM
VernMotor
Mt.Vernon ,Ohio
Looks good. I bought that indy valley plate used and them fittings was in it.
[Re: birdtracker]
#2937755
06/28/21 06:15 PM
06/28/21 06:15 PM
VernMotor
Mt.Vernon ,Ohio
I got mine back together and actually drove it down the road yesterday. Mine is 41 more cubic inches, but only 12.5-1 compression and a Bullet .685/ .685 cam. What fuel are you running ? And did the valley tray fit right in or did you have to have it machined? Birdtracker I run e-85 . I did't do anything to the plate fit good.
