Re: New style plastic windage tray
[Re: VernMotor]
#2935082
06/20/21 04:26 PM
06/20/21 04:26 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I mudded in some RTV into where the timing cover meets the block and the rear main seal holder, let dry/setup. Other than that, it went on dry
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: VernMotor]
#2935108
06/20/21 07:09 PM
06/20/21 07:09 PM
Posts: 12,088 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I've had one on my Hemi for 4 years now. I opened the slots some, too. Has worked fine, so far. I used Hylomar on the gaskets.
Master, again and still
[Re: 6PakBee]
#2935184
06/21/21 05:54 AM
06/21/21 05:54 AM
Posts: 10,027 MN
JERICOGTX
MN
Plastic? Oh God no, say it ain't so. They have been out for many years, and work just fine. I've had the same one for almost 10 years now.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2935244
06/21/21 10:29 AM
06/21/21 10:29 AM
Posts: 10,720 North Dakota
6PakBee
North Dakota
Plastic? Oh God no, say it ain't so. They have been out for many years, and work just fine. I've had the same one for almost 10 years now. I have been living under a rock!!
[Re: WV Runner]
#2935411
06/21/21 08:26 PM
06/21/21 08:26 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am using it on a repop 6 qt pan. Slathered it with Hylomar and it is good. Easy to pull off too, if I ever need to.
[Re: birdtracker]
#2936471
06/24/21 05:05 PM
06/24/21 05:05 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
There are two styles out there; one from Jegs that only works with rigid rail pans, and one from Summit that will work with all pans, including the factory stamped steel ones. I actually just ordered the Summit style. They recommend RTV applied sparingly at the two gaps at the front and rear, struck down and allowed to cure, and the tray installed DRY. Take your time and clean the mating surface thoroughly (scrape, brakleen, etc). I wouldn’t try to torque the bolts to the factory number.
[Re: Montclaire]
#2936474
06/24/21 05:18 PM
06/24/21 05:18 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
There are two styles out there; one from Jegs that only works with rigid rail pans, and one from Summit that will work with all pans, including the factory stamped steel ones. I actually just ordered the Summit style. They recommend RTV applied sparingly at the two gaps at the front and rear, struck down and allowed to cure, and the tray installed DRY. Take your time and clean the mating surface thoroughly (scrape, brakleen, etc). I wouldn’t try to torque the bolts to the factory number. Good to see that they are finally acknowledging what some of us already knew "This gasket works best with smooth rail oil pans. Dimpled oil pan rail may leak without silicone sealant." I kept asking , why would you put silicone or any type of sealant on a rubber o-ring molded type gasket ? Anyways this didn’t work on my 402 Oil Pan many moons ago Mancini started selling these years ago already On the Jegs website , I even see Mr Gasket has there own The Summit Racing doesn’t look any different then the other two that Jegs has listed ? I still run the factory windage tray , two superformance gaskets dry , and my 402 Oil Pan has been leak free for years
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Montclaire]
#2936680
06/25/21 12:30 PM
06/25/21 12:30 PM
metallicareload
Anchorage, Alaska
There are two styles out there; one from Jegs that only works with rigid rail pans, and one from Summit that will work with all pans, including the factory stamped steel ones. I actually just ordered the Summit style. They recommend RTV applied sparingly at the two gaps at the front and rear, struck down and allowed to cure, and the tray installed DRY. Take your time and clean the mating surface thoroughly (scrape, brakleen, etc). I wouldn’t try to torque the bolts to the factory number. I just assumed everyone is selling the same one. I've used two from Summit Racing, purchased years apart, and the've been used on the Mancini Racing stock style 6 quart repro pan (has the stiffening dimples between bolt holes) with no leaks. Installed it like you mention
