does anyone recognize these cam numbers? #2935152
06/20/21 10:33 PM
06/20/21 10:33 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
It's a solid roller camshaft with the following numbers scribed on the back. 324R-7/322R-3, SR10, D9856-05. Thanks for the help!
Re: does anyone recognize these cam numbers? [Re: dakotahotrodder] #2935210
06/21/21 08:39 AM
06/21/21 08:39 AM
an8sec70cuda Offline
I think that's a Comp Cams grind...I'll see if I can find something.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: does anyone recognize these cam numbers? [Re: an8sec70cuda] #2935280
06/21/21 12:28 PM
06/21/21 12:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Comp with old school “hi rpm” lobes.
New lobe numbers are 1309/4067
284/284-110
.456/.420 lobe lift
The D9856-05 is the serial number. The 05 indicates it was ground in 2005.
Re: does anyone recognize these cam numbers? [Re: fast68plymouth] #2935351
06/21/21 04:35 PM
06/21/21 04:35 PM
South Dakota
South Dakota
Thanks for the info Dwayne!
Re: does anyone recognize these cam numbers? [Re: dakotahotrodder] #2935613
06/22/21 12:23 PM
06/22/21 12:23 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
speed secrets revealed !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
