Re: Engine Masters: 6pack vs HEMI
[Re: hudsonhornet7x]
#2934947
06/19/21 11:37 PM
06/19/21 11:37 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
but who builds stock displacement engines anymore? I just did Fair enough lol. What did you build? Well to be fair to you, the answer to who builds stock displacement engines anymore is probably mostly no one. I think many prefer a power curve focused on low/lower rpm. I'm the opposite. I like short gearing and higher rpm, so kept stock crank, ported the heads, single plane intake, higher compression and solid roller.
[Re: moparpollack]
#2934963
06/20/21 05:51 AM
06/20/21 05:51 AM
Posts: 5,652 Port Huron, Michigan
MI_Custumz
If you insure through Hagerty they give you motor trend for free.
MT jumped the shark years ago haven't watched any new content in 3 years.
Had it for free for a year with Hagerty. Did they renew it so you can get another year? I never found a link or email on how to get another year free.
[Re: Uberpube]
#2934988
06/20/21 10:14 AM
06/20/21 10:14 AM
Posts: 3,519 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Anyone watch it? Interesting results. Has me wondering if the cams should have shared the same lift but otherwise been customized to suite each engine best. How about a link to it so we can watch it They are having a Father's Day sale, $36 a year. Well worth it. https://www.motortrend.com/news/motortrend-app-fathers-day-gifts/ Deal only available in the US. Bummer. Can you subscribe at all? Some folks outside the U.S. cannot get it for any price. I wish you all would open the boarder up and let the racers come see us.
[Re: GTX MATT]
#2935042
06/20/21 01:14 PM
06/20/21 01:14 PM
Posts: 1,709 central il.
second 70
central il.
I did not know that Stage V made a dual plane? Somehow I suspect that a stock intake would have made more torque. https://www.hotrod.com/articles/mopp-0310-hemi-426-crate-engine-dyno-test/This is an article from Dulcich on Westechs dyno from 20 years ago. The otherwise stock 465 HP crate motor he used made WAY more low end torque with more cam with the crate motor intake manifold. How much do you want to bet its actually the same crate engine? Here's the spec's on that crane cam they used in that article. I run it too with a stage V single plane 2-4 manifold. Dyno pull needed to go up to at least 7500rpm.
[Re: GTX MATT]
#2935266
06/21/21 11:28 AM
06/21/21 11:28 AM
340Cuda
Tulsa, Oklahoma
How much do you want to bet its actually the same crate engine? He said on the show that the engine came out of a car he had, never mentioned it being a crate engine. They even showed the car on the show.
[Re: 340Cuda]
#2935283
06/21/21 12:58 PM
06/21/21 12:58 PM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
How much do you want to bet its actually the same crate engine? He said on the show that the engine came out of a car he had, never mentioned it being a crate engine. They even showed the car on the show. At the 7min mark onward he said it was a very early crate Hemi.
[Re: cudaman1969]
#2935500
06/22/21 01:38 AM
06/22/21 01:38 AM
Posts: 6,007 Salem
Grizzly
Moparts Proctologist
Salem
So glad you wedge guys had no say so when Chrysler decided to build the HEMI. Really could that wedge run 1 2 3 4 at Daytona in 64? Indeed. We still have time to stop all this Gen 3 Hemi nonsense and re-engineer a head that makes some power.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2935508
06/22/21 02:11 AM
06/22/21 02:11 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Like I mentioned earlier
The 440 - 6 came out of a 1971 Dodge Charger R/T many moons ago
Steve Dulchich first car he said - That was the car shown on the episode of Engine Masters
It will go back into the car he said after all these years at some point - He pulled the 440 - 6 out when he was a youngster , one of his first engines he rebuilt and played with
The 426 Hemi is a Mopar Performance Crate motor circa 1994/1995
It is going into a AMC Gremlin on a future episode of Roadkill
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Grizzly]
#2935569
06/22/21 10:04 AM
06/22/21 10:04 AM
Posts: 12,157 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Mopar's first V-8 was a Hemi. The only reason they got away from that design was simple economics. When they needed a horsepower boost, they went back to that design. When they needed a modern V-8 to compete globally, they again turned to the Hemispherical combustion chamber. And today, it is the design of choice for the fastest and quickest vehicles on earth.
Does anyone here believe that the current crop of Demons, Hellcats, and Redeyes would be as fast/efficient with wedges rather than Hemis?
Our wedges are certainly great engines. But the hemispherical combustion chamber that allows for a better valve arrangement is simply much more efficient. And when taken to it's logical extremes, cannot be beat. That continues to be proven over and over again. Any mod or improvement to a wedge head can be trumped by modifications to a Hemi head. The only times that a wedge head wins is when a Hemi head is saddled with half measures.
Now, it is a fair argument that in many applications (actually most applications), the additional complexity and expense of the Hemi design is not worth the trouble given the level of performance being sought. But then the argument becomes performance bang-for-the-buck, not overall superiority. Which is essentially the same decision that Mopar came to in the late 50s.
Master, again and still
[Re: 73DAD]
#2935598
06/22/21 11:53 AM
06/22/21 11:53 AM
340Cuda
Tulsa, Oklahoma
How much do you want to bet its actually the same crate engine? He said on the show that the engine came out of a car he had, never mentioned it being a crate engine. They even showed the car on the show. At the 7min mark onward he said it was a very early crate Hemi. I thought we were talking about the 440, I may have misunderstood.
[Re: DaveRS23]
#2935758
06/22/21 06:20 PM
06/22/21 06:20 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Our wedges are certainly great engines. But the hemispherical combustion chamber that allows for a better valve arrangement is simply much more efficient. And when taken to it's logical extremes, cannot be beat. That continues to be proven over and over again. Any mod or improvement to a wedge head can be trumped by modifications to a Hemi head. The only times that a wedge head wins is when a Hemi head is saddled with half measures. I'm not smart enough to explain why but I remember Monte Smith always mentioning the Hemi was best suited to boosted applications. For N/A or on spray, a canted valve style head with symmetric exhaust ports was the best option.
[Re: Blusmbl]
#2935940
06/23/21 10:06 AM
06/23/21 10:06 AM
Posts: 1,051 The Great White North
RAMM
It's because of the already "softened" chamber<<< I dislike that terminology--It's scalloped IMO. The HEMI has a factory scalloped chamber that widens the tuning window significantly under power adder applications--Basically the HEMI chamber is a slow burning chamber which is why when you add a second plug--things change so much. Hate to say it but a single plug wide open 170cc chamber is inefficient. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
