Ok whats goin on here--bad vibe???????? #293044
04/19/09 05:38 PM
04/19/09 05:38 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
well my motor has been done for a little over a year now and I am STILL having a little vibration problem. It doesnt do it all the time sometimes when you come off the highway and start to slow down you can feel it. It's a stroker kit from 440 source had them balance it as well do you think it could be the balancer?? I believe I have a scat(not sure got it off ebay)sfi bal on there now maybe I should put a TCI rattler on? Looking for any help.
Thanks guys
Duke
Re: Ok whats goin on here--bad vibe???????? [Re: WICKD6PK] #293045
04/19/09 05:43 PM
04/19/09 05:43 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Get the rattler on now, the scat unit I had kept coming loose and would not stay tight...Phill
Re: Ok whats goin on here--bad vibe???????? [Re: 9 Sec Phill] #293046
04/19/09 05:55 PM
04/19/09 05:55 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
It also seems to do this at different rpm ranges maybe that bal I got was/is junk--I hope I didnt hurt anything by running that for a while around 1000 miles....I guess that 'ol saying is true ya get what ya pay for
Re: Ok whats goin on here--bad vibe???????? [Re: WICKD6PK] #293047
04/19/09 10:05 PM
04/19/09 10:05 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
anybody else ati,rattler or stock balancer?? or am I looking at the wrong thing/problem?????
Re: Ok whats goin on here--bad vibe???????? [Re: WICKD6PK] #293048
04/20/09 01:18 AM
04/20/09 01:18 AM
Cab_Burge Online work
Cab_Burge  Online Work
9seconphil had a CAT balancer, not SCAT. I use, like and recommend the ATI brand, not the TCI Rattlers. I have heard that the TCI Rattlers break crankshafts If the car vibrates under deaccleration and not at the same speed cruising or under acceleration you probally have a drivetrain related problem, not a motor problem
Re: Ok whats goin on here--bad vibe???????? [Re: Cab_Burge] #293049
04/20/09 06:49 AM
04/20/09 06:49 AM
go with the ATI Superbalancer. nothing else.
im not happy with fluidampers or tci rattlers at all.
Re: Ok whats goin on here--bad vibe???????? [Re: Cab_Burge] #293050
04/20/09 08:00 AM
04/20/09 08:00 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
On decell sounds like driveline
Re: Ok whats goin on here--bad vibe???????? [Re: emarine01] #293051
04/20/09 03:47 PM
04/20/09 03:47 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
ok first--- thanks for all the input guys! you guys are the best. well I guess I'm takin the driveshaft back to the place that made it for me and have them recheck it to make sure it's balanced correctly--i had a 8 3/4 rear in there and when I switched to the dana they had to put on a bigger end for the bigger yolk so I'm wonderin if they rebalanced it or said good enough-although I doubt they would do that they are a great bunch of guys but they said they would check it out again for me. Now if that checks out ok where do I look next? I have a new Hughes converter in there hell everything is new but I know that doesnt mean anything I know you can still get something a little out of spec.
Duke
Re: Ok whats goin on here--bad vibe???????? [Re: WICKD6PK] #293052
04/20/09 04:06 PM
04/20/09 04:06 PM
an8sec70cuda Offline
The driveshaft needs to be shortened when switching to a Dana from an 8 3/4. Did you measure what length you needed after you put the dana in? CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Ok whats goin on here--bad vibe???????? [Re: WICKD6PK] #293053
04/20/09 04:22 PM
04/20/09 04:22 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if it's in the engine, you should be able to feel it revving the motor in park/neutral and the car stationary.
or you could discount anything in the engine if you put the car in neutral and turn it off as you decell....if you feel it, then it can't be the motor or input side of the torque converter (as it would be stationary). could be driveshaft balance, tire balance, tire out of round, pinion angle, rear tranny mount, tranny output bushing, etc....
2017 Grand Cherokee Overland
Re: Ok whats goin on here--bad vibe???????? #293054
04/20/09 04:43 PM
04/20/09 04:43 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
WHATS YOUR BEEF WITH FLUIDAMPERS? JUST CURIOUS.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Ok whats goin on here--bad vibe???????? [Re: an8sec70cuda] #293055
04/20/09 07:56 PM
04/20/09 07:56 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
Hey Chip yep I had to have the shaft shortend cant remember the exact # off hand, but we'll see what they say on Tues. after work.
Re: Ok whats goin on here--bad vibe???????? [Re: Old School] #293056
04/20/09 08:05 PM
04/20/09 08:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
besides many known cases of the jell getting hard and to many broken crank shafts to count, probably nothing
Re: Ok whats goin on here--bad vibe???????? [Re: Quicktree] #293057
04/21/09 03:34 PM
04/21/09 03:34 PM
NY
W
WICKD6PK Offline OP
WICKD6PK  Offline OP
W
NY
Ok got back from the shop & they tell me the driveshaft is twisted from the trans yolk about 1/4-1/2 way down the shaft. They got it balanced but it's still not straight so I guess a new tube is in store for me--I hope this is not going to be a ongoing problem......
