Re: Ok whats goin on here--bad vibe????????
[Re: Cab_Burge]
#293049
04/20/09 06:49 AM
04/20/09 06:49 AM
go with the ATI Superbalancer. nothing else. im not happy with fluidampers or tci rattlers at all.
[Re: Cab_Burge]
#293050
04/20/09 08:00 AM
04/20/09 08:00 AM
Posts: 3,695 nc
emarine01
nc
9seconphil had a CAT balancer, not SCAT. I use, like and recommend the ATI brand, not the TCI Rattlers. I have heard that the TCI Rattlers break crankshafts If the car vibrates under deaccleration and not at the same speed cruising or under acceleration you probally have a drivetrain related problem, not a motor problem
On decell sounds like driveline
[Re: WICKD6PK]
#293052
04/20/09 04:06 PM
04/20/09 04:06 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
The driveshaft needs to be shortened when switching to a Dana from an 8 3/4. Did you measure what length you needed after you put the dana in? CHIP
[Re: WICKD6PK]
#293053
04/20/09 04:22 PM
04/20/09 04:22 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if it's in the engine, you should be able to feel it revving the motor in park/neutral and the car stationary.
or you could discount anything in the engine if you put the car in neutral and turn it off as you decell....if you feel it, then it can't be the motor or input side of the torque converter (as it would be stationary). could be driveshaft balance, tire balance, tire out of round, pinion angle, rear tranny mount, tranny output bushing, etc....
[Re: Old School]
#293056
04/20/09 08:05 PM
04/20/09 08:05 PM
Quicktree
WHATS YOUR BEEF WITH FLUIDAMPERS? JUST CURIOUS.
besides many known cases of the jell getting hard and to many broken crank shafts to count, probably nothing
