2000 van 5.9 and trans into 68 Dart
#2929570
06/02/21 06:10 PM
06/02/21 06:10 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I got a 2000 van with a 5.9 and I want to put it and trans and EFI into 68 Dart....Anyone have a good reference thread on someone whos done this?....The van throttle body pulls from the front, can it just be turned around? the 68 Dart was a 273 car I have an Abody 8 3/4 all ready. I need a chunk for it....sure grip clutch type with 3.23 hoping to find. Thanks for any help.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 2000 van 5.9 and trans into 68 Dart
[Re: HemiRick]
#2929614
06/02/21 08:04 PM
06/02/21 08:04 PM
Andrewh
So I put a 2000 5.9 from a Durango in a 65 coronet. For the throttle, I modified the 5.9 cable so it would work with the original gas pedal. So I didn't change the mounting on the motor at all. I kept my 727 and used an aftermarket system to control the efi. The van setup is a little different, but nice because it tucks the power dr steering pump closer to the engine. Otherwise it sits under the battery tray.
[Re: poorboy]
#2929678
06/03/21 12:51 AM
06/03/21 12:51 AM
HemiRick
Memphis
Yes it pulls from the front on the passenger side, that's why I was thinking I could just turn it around...then it would pull to the rear on the drivers side like I need. Using the van pedal may work but then I have a extra long cable that's not really needed. I have a 98 Dakota here need to see what it has. (Edit: Looks like that might work!) Yes I plan to use the van PCM and wiring, I understand the PCM just needs a start, run, and ground from the original car. Would love to put the van instrument panel in too. Looks like it might fit.....
