dash frame clips ?? #2929469
06/02/21 12:48 PM
06/02/21 12:48 PM
taunton, mass. 02780
moparthunder70 Offline OP
Hey Guys, I need your help...I'm in the process of installing an instrument cluster and lower dash pad on a 69 roadrunner...I'm puzzled about these clips ? where do they go ?
Re: dash frame clips ?? [Re: moparthunder70] #2929477
06/02/21 01:05 PM
06/02/21 01:05 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Those are for the heater/defroster hose to the vents clips
Re: dash frame clips ?? [Re: Cuda340] #2929482
06/02/21 01:19 PM
06/02/21 01:19 PM
Thank you...had me stumped..appreciate the info..
Re: dash frame clips ?? [Re: moparthunder70] #2929500
06/02/21 02:01 PM
06/02/21 02:01 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Anyone have a close-up picture of how these get installed?
Re: dash frame clips ?? [Re: burdar] #2929529
06/02/21 03:56 PM
06/02/21 03:56 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Pushed onto vent tubes and then hoses push on, near as I can figure, but probably also work hose 1st/vent 2nd.
Either way, a sumbiotch to remove hoses once installed laugh2
Re: dash frame clips ?? [Re: topside] #2929630
06/02/21 08:48 PM
06/02/21 08:48 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree beer
Re: dash frame clips ?? [Re: TJP] #2929699
06/03/21 08:53 AM
06/03/21 08:53 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So, the longer side of the clip goes to the outside and the hose is pushed on after the clip is in place? That seems like something the factory would engineer. (quick and easy to install on the line)
Will those factory clips work with the replacement hoses? I think those are rubber and not wire/paper like originals.( I have some but I guess I haven't taken them out of the box to look)
Re: dash frame clips ?? [Re: burdar] #2929709
06/03/21 10:01 AM
06/03/21 10:01 AM
A collage of whims
A collage of whims
Last I heard, the "repro" plastic hoses are a bit too large.
But yes, the idea back in the day was to stab the stuff together quickly.
Re: dash frame clips ?? [Re: topside] #2930688
06/06/21 11:01 PM
06/06/21 11:01 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Just checked my reproduction hoses. I initially thought they were just solid rubber, molded to look like the original ducts. They do however have a wire core. Instead of the factory paper like stuff wrapped around the wire, the reproductions are rubber with a wire core. I slid one onto a spare dash duct that had one of those clips installed. It pushs on over the clip and then locks in place. Works pretty good.
The reproduction hoses are both the same size and fit over the dash ducts. They come with two adapters for the heater box. The adapters have different IDs so they fit the heater box...then the hoses push onto those adapters.
