Treadwear rating #2928928
05/31/21 03:48 PM
05/31/21 03:48 PM
Iceland
BadMoonRacer Offline OP
Iceland
Hello fellow Moparians
I need to know a.s.a.p.the treadwear rating for Mickey Thompson Sportsman S/R tires.
I have been searching the web without any luck.
Please respond if you know it or can cite a website with that info.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Treadwear rating [Re: BadMoonRacer] #2928941
05/31/21 04:24 PM
05/31/21 04:24 PM
Iceland
Iceland
Well, I guess nobody knows the answer since the manufacturer does not have that info. This is from Jeg´s website:
UTQG Tread Wear Rating
N/A
Temperature Rating
N/A
Traction Rating
N/A
How come they won´t divulge this necessary info??
Re: Treadwear rating [Re: BadMoonRacer] #2929070
06/01/21 07:45 AM
06/01/21 07:45 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I would guess it because they are "Performance" tires and therefore wont put a wear rating (guarantee) on them.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Treadwear rating [Re: BadMoonRacer] #2929086
06/01/21 09:26 AM
06/01/21 09:26 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
N/A
Temperature Rating
N/A
Traction Rating
N/A
I believe its required by law to at least be on the new tire sticker, how you force the issue before purchase, is beyond me. Only applicable exception I can think of is if tire is clearly marked "Race only,"" or "not foe use on public roads". twocents
Its not an end all, be all number anyway. kinda like trying to judge how fast a car is by only asking its weight.
Re: Treadwear rating [Re: jcc] #2929252
06/01/21 05:43 PM
06/01/21 05:43 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
Re: Treadwear rating [Re: plycuda] #2929326
06/01/21 09:24 PM
06/01/21 09:24 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
One important note on this; the wear ratings are only manufacturer specific. They only compare to other tires in that particular manufacturer's line. The ratings have no relevance to ratings on other manufacturer's tires. Of course, the 000 wear rating on my drag radials is not a real point of comparison anyway.
Master, again and still
Re: Treadwear rating [Re: plycuda] #2929587
06/02/21 06:51 PM
06/02/21 06:51 PM
Iceland
Iceland
Thank you for this info plycuda, I wonder what the difference is between the S/R and S/T Sportmans.
Re: Treadwear rating [Re: BadMoonRacer] #2929654
06/02/21 09:43 PM
06/02/21 09:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
There is a huge difference in the compound of the S/R and S/T. My 275/60/15 S/T's are like driving on ice.
'63 Dodge 330
11.19 @ 121 mph
Re: Treadwear rating [Re: BadMoonRacer] #2929932
06/03/21 10:31 PM
06/03/21 10:31 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
yeah the st are junk.the sportsman pro are not the greatest but they aren't to bad especially if you get caught in the rain they won't try to kill you. are you running in a class that has to have a certain tread wear rating.
Re: Treadwear rating [Re: plycuda] #2930120
06/04/21 07:29 PM
06/04/21 07:29 PM
Iceland
Iceland
We are running in a class that says "Only true radial tires allowed, Drag radials and soft compound tires not allowed." One competitor showed up on M/T E.T: Street and another on R/T Sportsmans. A debate ensued if the R/T´s would qualify as soft compound, the E.T. were definately illegal. The wisdom I have picked up on the www is that "true" radials have a treadwear of 400 and higher. The R/T´s do not give any info about its treadwear.
You can see a video of these races here: https://www.youtube.com/watch?v=egkLVtFVWZY
My Charger had a bad day; spinning the wheels almost half track. There is another race on June 19th. I plan to do better then
Thank you for your interest,
Ragnar in iceland
Re: Treadwear rating [Re: BadMoonRacer] #2930141
06/04/21 09:05 PM
06/04/21 09:05 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
we have a daily driver class that has to be 200 or more . everyone is running the nitto tires there 200
