Howard's BB hydr roller cam #2928876
05/31/21 01:01 PM
05/31/21 01:01 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
https://www.summitracing.com/parts/hrs-723515-12/make/chrysler
Like to try one in a stock-type 440. I think it would be just fine, thought I would ask here if anyone had used this particular cam.
272/278 - 219/225 - 112
.510" / .500" lift with 1.5rr
Performer RPM with center divider welded up
700 Holley
1.875 headers
Re: Howard's BB hydr roller cam [Re: hemienvy] #2928877
05/31/21 01:09 PM
05/31/21 01:09 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I''m using the slightly larger .545 lift version in my 505. Lots of miles and use and it has worked really well with zero issues.
'63 Dodge 330
11.19 @ 121 mph
Re: Howard's BB hydr roller cam [Re: GY3] #2928882
05/31/21 01:28 PM
05/31/21 01:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Not to hijack but what springs are you guys using on the hydraulic roller cams? I watched Vizards video on beehive springs and was wondering if there were any new advancements in hydraulic roller springs.
I went with a little too much flat cam in my street car so I was thinking of going to a "smaller" cam either solid roller or hydraulic roller.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howard's BB hydr roller cam [Re: fourgearsavoy] #2928895
05/31/21 02:02 PM
05/31/21 02:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Gus beer
Unfortunately, the springs had been put on the heads before I got them. I had the machinist check them out and he said they were good to go. I have no information on what they are.
'63 Dodge 330
11.19 @ 121 mph
