Mopar RV2 A/C Compressor (Do they make)? Have you seen one? #2927196
05/27/21 10:20 AM
05/27/21 10:20 AM
Mid-West
P
ply478 Offline OP
ply478  Offline OP
P
Mid-West
I am getting closer to the end of a 360 LA project.
Long story here. So my quick question is, Has anyone ever seen a A/C Delete Double Pulley for an RV2 Compressor?
This would let one remove the A/C clutch, remove the RV2 Cast compressor. And then bolt in the delete kit with double belt pulley, so I could add the A/C at a later date.
I could have sworn that I have seen these on some cars and truck late 70's to mid 80's
Any input would be greatly helpful, and maybe you have one in your Box O extra parts.
Picture of a RV2 Compressor attached.
PLY478
I am also a Vintage Motorcycle guy. Mainly Spanish built "Bultaco's" If you have one or parts PM me.+
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: ply478] #2927216
05/27/21 12:10 PM
05/27/21 12:10 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I know they used to make them for maybe late 70s or 80s cars.
Whether or not they still do I seriously doubt.
finding one would be some task , unless you get really lucky
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: gtx6970] #2927235
05/27/21 01:05 PM
05/27/21 01:05 PM
moparx Offline
moparx  Offline
i just sold this exact setup to a member here a couple of weeks back. it came from a 74 chrysler newport with a 400.
as the pulley setup was attached to only the water pump housing, it worked on his 440.
the same pulley arrangement was also used on trucks in the 70's, but i can't say the exact year range.
beer
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: ply478] #2927293
05/27/21 03:16 PM
05/27/21 03:16 PM
moparx Offline
moparx  Offline
a couple more pics..........
beer
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: moparx] #2927370
05/27/21 06:45 PM
05/27/21 06:45 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I guess this later style for LA small block wouldn't work? I have one of these from '88 Diplomat Police. Sure looks different I know.
Facts are stubborn things.
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: larrymopar360] #2927393
05/27/21 07:31 PM
05/27/21 07:31 PM
Mid-West
P
ply478 Offline OP
ply478  Offline OP
P
Mid-West
Larry that might be it. The only thing I need to find out is if that 88 Cop car had the RV2 compressor. Although I believe that it would have had the Aluminum style C171 compact A/C and I see that Bad guy hauler has the 100amp alternator. So that large bracket is special to those parts. I will send you a PM. Thanks PLY 478
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: ply478] #2927403
05/27/21 07:58 PM
05/27/21 07:58 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Sorry it did not have the RV2 it had the crappy round one I just thought someone might chime in and say there's a way to use later idler pulley and they've done it.
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: larrymopar360] #2927723
05/28/21 03:08 PM
05/28/21 03:08 PM
Mid-West
P
ply478 Offline OP
ply478  Offline OP
P
Mid-West
I knew I have seen these on LA Engines.... With a standard 60 amp alternator!
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: ply478] #2927800
05/28/21 05:44 PM
05/28/21 05:44 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
So probably '79 back to ?
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: larrymopar360] #2928023
05/29/21 10:39 AM
05/29/21 10:39 AM
5thAve Offline
5thAve  Offline
Or an 80s 318/360 vehicle that has the old style alternator. They still use the older style alternator bracket not the big one that wraps around the passenger side of the AC compressor.
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: 5thAve] #2928037
05/29/21 11:43 AM
05/29/21 11:43 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
But would that work because it was not the RV2 a/c?
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: larrymopar360] #2928314
05/29/21 09:18 PM
05/29/21 09:18 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Last year for the Rv2 was '79 I believe. I don't think the round '80 up compressor brackets would work. I've seen the idler setup on a few 70's trucks as pictured but don't recall seeing them on a car.
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: 440newport] #2928396
05/30/21 07:59 AM
05/30/21 07:59 AM
RWG75
RWG75
79 was last year for the RV2 and when they changed compressors they all changed the intake. Had to move the thermostat location a little bit to clear.
A/C delete idlers on 70s cars are pretty uncommon - I mean how many non a/c late 70s cars have ya really seen? A bodies sure, but extremely rare on B and C bodies. Best bet here is find an factory parts book, look up the bracket numbers, start messaging people on FB. I hate to endorse that place but it's the new go to and where I found the idler setup for big block truck water pump w/o A/C. Oddly enough, at least part of that setup was also used for mounting air pumps on big block C bodies.
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: ] #2928967
05/31/21 05:37 PM
05/31/21 05:37 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I just sold a 78 non-a/c bigblock Cordoba I had bought for parts. I could ask the buyer if he'd let that piece go.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: Magnumguy] #2929196
06/01/21 03:10 PM
06/01/21 03:10 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
He's looking for small block bracket.
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one? [Re: larrymopar360] #2929237
06/01/21 04:59 PM
06/01/21 04:59 PM
scratchnfotraction Offline
I have the pulleys/brackets for a/c delete off of a 88 B150 318 TBI intake IIRC. but fit the late LA 4v intakes with sanden comp.
it used the small alt with a jack-bolt to torque the belt. big brackets and would use a sanden comp. complete set up and has a bolt on idler pulley and bracket in place of the comp unit. TBI = fuel pump block off plate
even these mid-late 80s a/c delete brackets pulleys are hens teeth when you need to replace just the idler pulley/bracket.
I want to say that the small arm/pulley that bolts to a/c brackets are the same SB to BB just the brackets are different. I will have to have another look in the shed and see if it looks like the pics posted IIRC it has 3 bolts?
I may have a single a/c delete pulley that came off a 440 c-body no a/c or it is an idler pulley for a/c???
