Mopar RV2 A/C Compressor (Do they make)? Have you seen one?
#2927196
05/27/21 10:20 AM
05/27/21 10:20 AM
Posts: 1,097 Mid-West
ply478
Mid-West
I am getting closer to the end of a 360 LA project.
Long story here. So my quick question is, Has anyone ever seen a A/C Delete Double Pulley for an RV2 Compressor?
This would let one remove the A/C clutch, remove the RV2 Cast compressor. And then bolt in the delete kit with double belt pulley, so I could add the A/C at a later date.
I could have sworn that I have seen these on some cars and truck late 70's to mid 80's
Any input would be greatly helpful, and maybe you have one in your Box O extra parts.
Picture of a RV2 Compressor attached.
PLY478
I am also a Vintage Motorcycle guy. Mainly Spanish built "Bultaco's" If you have one or parts PM me.+
Re: Mopar RV2 A/C Compressor (Do they make)? Have you seen one?
[Re: gtx6970]
#2927235
05/27/21 01:05 PM
05/27/21 01:05 PM
Posts: 19,480 north of coder
moparx
i just sold this exact setup to a member here a couple of weeks back. it came from a 74 chrysler newport with a 400. as the pulley setup was attached to only the water pump housing, it worked on his 440. the same pulley arrangement was also used on trucks in the 70's, but i can't say the exact year range.
[Re: moparx]
#2927370
05/27/21 06:45 PM
05/27/21 06:45 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I guess this later style for LA small block wouldn't work? I have one of these from '88 Diplomat Police. Sure looks different I know.
Facts are stubborn things.
[Re: larrymopar360]
#2927393
05/27/21 07:31 PM
05/27/21 07:31 PM
ply478
Mid-West
Larry that might be it. The only thing I need to find out is if that 88 Cop car had the RV2 compressor. Although I believe that it would have had the Aluminum style C171 compact A/C and I see that Bad guy hauler has the 100amp alternator. So that large bracket is special to those parts. I will send you a PM. Thanks PLY 478
[Re: ply478]
#2927403
05/27/21 07:58 PM
05/27/21 07:58 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Sorry it did not have the RV2 it had the crappy round one I just thought someone might chime in and say there's a way to use later idler pulley and they've done it.
[Re: larrymopar360]
#2927723
05/28/21 03:08 PM
05/28/21 03:08 PM
ply478
Mid-West
I knew I have seen these on LA Engines.... With a standard 60 amp alternator!
[Re: ply478]
#2927800
05/28/21 05:44 PM
05/28/21 05:44 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
So probably '79 back to ?
[Re: larrymopar360]
#2928023
05/29/21 10:39 AM
05/29/21 10:39 AM
Posts: 4,153 Canada -- Posts: 4034 -Registe...
5thAve
Or an 80s 318/360 vehicle that has the old style alternator. They still use the older style alternator bracket not the big one that wraps around the passenger side of the AC compressor.
[Re: 5thAve]
#2928037
05/29/21 11:43 AM
05/29/21 11:43 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Or an 80s 318/360 vehicle that has the old style alternator. They still use the older style alternator bracket not the big one that wraps around the passenger side of the AC compressor. But would that work because it was not the RV2 a/c?
[Re: 440newport]
#2928396
05/30/21 07:59 AM
05/30/21 07:59 AM
RWG75
RWG75
79 was last year for the RV2 and when they changed compressors they all changed the intake. Had to move the thermostat location a little bit to clear.
A/C delete idlers on 70s cars are pretty uncommon - I mean how many non a/c late 70s cars have ya really seen? A bodies sure, but extremely rare on B and C bodies. Best bet here is find an factory parts book, look up the bracket numbers, start messaging people on FB. I hate to endorse that place but it's the new go to and where I found the idler setup for big block truck water pump w/o A/C. Oddly enough, at least part of that setup was also used for mounting air pumps on big block C bodies.
[Re: Magnumguy]
#2929196
06/01/21 03:10 PM
06/01/21 03:10 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just sold a 78 non-a/c bigblock Cordoba I had bought for parts. I could ask the buyer if he'd let that piece go. He's looking for small block bracket.
