CopperKote antisieze on spark plug threads ? #2926168
05/24/21 01:40 PM
05/24/21 01:40 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Anyone do this ?
Plugs need a good ground, I have read to use oil but that doesn't seem like a good idea.
Re: CopperKote antisieze on spark plug threads ? [Re: hemienvy] #2926169
05/24/21 01:41 PM
05/24/21 01:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by hemienvy
Anyone do this ?
I do on my aluminum heads.
'63 Dodge 330
11.19 @ 121 mph
Re: CopperKote antisieze on spark plug threads ? [Re: hemienvy] #2926182
05/24/21 02:28 PM
05/24/21 02:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Read a bulletin years ago from NGK that said NOT to use the copper as it makes the plug hard to ground in the head and that Alum. anti-seize was better. I use motor oil myself....
Re: CopperKote antisieze on spark plug threads ? [Re: Thumperdart] #2926196
05/24/21 03:03 PM
05/24/21 03:03 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I use copper anti-seize on the threads only. I'd like to see whoever claims that anti-seize on the threads hinders the ground provide some test information. I'm sure the contact between the seat of the spark plug, the aluminum spark plug tube, and the cylinder head provide plenty of ground even if the threads were completely insulated by the anti-seize.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: CopperKote antisieze on spark plug threads ? [Re: hemienvy] #2926203
05/24/21 03:11 PM
05/24/21 03:11 PM
I learn to use liquid graphite anti seize, Champion plug brand, on my airplane spark plugs in aluminum heads back in the early 1990s, I've been using on the street and race motors with aluminum heads every since then up scope A few drops on the threads works great thumbs
Re: CopperKote antisieze on spark plug threads ? [Re: Cab_Burge] #2926217
05/24/21 03:46 PM
05/24/21 03:46 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I've also used lead and aluminum based antisieze, whatever is on hand. No problems with grounding.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: CopperKote antisieze on spark plug threads ? [Re: hemienvy] #2926221
05/24/21 04:03 PM
05/24/21 04:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Been a mechanic for over 35 years and probably installed a couple thousand plugs with just a couple drops of oil on the threads .
Gus beer
64 Plymouth Savoy
Dana 60
Re: CopperKote antisieze on spark plug threads ? [Re: hemienvy] #2926230
05/24/21 04:58 PM
05/24/21 04:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the plugs are R&R regularly oil is OK. For really long intervals, it becomes carbon and will engrave aluminum threads.
Anti-seize reduces heat transfer, but apparently not enough to matter.
Boffin Emeritus
Re: CopperKote antisieze on spark plug threads ? [Re: polyspheric] #2926237
05/24/21 05:12 PM
05/24/21 05:12 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
My understanding is that CopperKote is used by electricians to fasten rigid electrical conduit together.
It is conducting and keeps the grounding continuous. Also inhibits rust.
Re: CopperKote antisieze on spark plug threads ? [Re: hemienvy] #2926242
05/24/21 05:38 PM
05/24/21 05:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2. Besides, the washer or taper on the plug still seats on the head for a good round.
Re: CopperKote antisieze on spark plug threads ? [Re: rickraw] #2926260
05/24/21 07:12 PM
05/24/21 07:12 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1. Anti-seize
NGK spark plugs feature trivalent plating. This silver or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without lubrication or anti-seize.
Anti-seize can act as a lubricant, altering torque values up to 20 percent, increasing the risk of spark plug thread breakage and/or metal shell stretch. Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental.
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: CopperKote antisieze on spark plug threads ? [Re: bee1971] #2926432
05/25/21 11:08 AM
05/25/21 11:08 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks cos some still need to argue with the FACTS......
Re: CopperKote antisieze on spark plug threads ? [Re: bee1971] #2926456
05/25/21 12:06 PM
05/25/21 12:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by bee1971
1. Anti-seize
Good to know!
'63 Dodge 330
11.19 @ 121 mph
Re: CopperKote antisieze on spark plug threads ? [Re: GY3] #2926462
05/25/21 12:33 PM
05/25/21 12:33 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Just to support the "dont use antisieze" movement. as someone mentioned previously it also prohibits heat transfer, This overheats the plug and causing pre detonation and premature plug failure.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: CopperKote antisieze on spark plug threads ? [Re: W.I.N. Racing] #2926470
05/25/21 12:48 PM
05/25/21 12:48 PM
America
WedgeFED Offline
WedgeFED  Offline
America
This subject gets beat to death. Been a mechanic for well over 30 years. Never and I repeat Never has even one manufacturer ever used lube of any sort on any spark plug thread ever...
Re: CopperKote antisieze on spark plug threads ? [Re: W.I.N. Racing] #2926473
05/25/21 12:54 PM
05/25/21 12:54 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Well, I've used anti-sieze (nickel) on spark plug threads for over 30 years. Iron heads, aluminum heads, flat seat, tapered seat, domestic and imported, small engine and large engine. Haven't had one problem. You have to realize what the head material is and how anti-sieze affects the torque but I would think any competent mechanic should realize those two factors when installing plugs.
Re: CopperKote antisieze on spark plug threads ? [Re: 6PakBee] #2926483
05/25/21 01:33 PM
05/25/21 01:33 PM
central il.
second 70 Online content
second 70  Online Content
central il.
What I have read from NGK they say none on their plugs on Aluminum heads but yes on the black threaded plugs like AC and autolite on aluminum heads.
Re: CopperKote antisieze on spark plug threads ? [Re: second 70] #2926490
05/25/21 02:08 PM
05/25/21 02:08 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Every time I have ever removed a spark plug and the threads came out with it the reason was because they were clearly installed dry. Not such a big deal with hot rods and such with short removal intervals but the newer engines with double iridium that are supposed to be in the engine over 100,000 or just lazy people running others that long is where they get siezed in the head and ruin the threads. On customer cars I always use something because you never know how long they will try to run before they ever replace plugs again. A mechanic with any feel for what he is doing can tighten it without stripping it.
As for heat transfer, if anything it would make the plug run colder not hotter, only silver conducts heat faster than copper, the copper will transfer heat faster as the particles fill space and make more contact with the steel on steel or steel on aluminum.
Re: CopperKote antisieze on spark plug threads ? [Re: HotRodDave] #2926544
05/25/21 04:09 PM
05/25/21 04:09 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I don't use NGK, so their coating is irrelevant to me. Why spend the big bucks on them, when AC's work just as well at 1/4 the price.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: CopperKote antisieze on spark plug threads ? [Re: Hemi_Joel] #2926564
05/25/21 04:44 PM
05/25/21 04:44 PM
PA
moparacer Offline
moparacer  Offline
PA
I run NGK and have never put any anti seize on them. I dont do a incredible hulk impression when I tighten them either, however. hammer
Anti sieze has it place but I wont put it on anything that I have to remove at regular intervals.
Its a mess and gets on EVERYTHING...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
