74 truck 8/34 interchange #2922275
05/13/21 10:52 PM
05/13/21 10:52 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Does this axle interchange with any cars especially 71/79 b bodies?
Re: 74 truck 8/34 interchange [Re: chargers777] #2922277
05/13/21 10:58 PM
05/13/21 10:58 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The truck unit is 1-3/8" wider than the 71-4 B unit.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 74 truck 8/34 interchange [Re: moparmarks] #2922311
05/14/21 01:33 AM
05/14/21 01:33 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
The 72-74 2wd truck 8 3/4 is basically the same axle assembly as the 70-74 C Body except the spring perches are welded on the opposite side and are A Body width also there is a difference between 72-74 2wd and 4wd truck axle assemblies, the 2wd has the common 4.5" bolt pattern the same as the dodge cars and the 4wd axle assembly has the 5.5" bolt pattern which common with some of the Ford trucks in the day. They are pretty wide axle assemblies for most of the B bodies.
Re: 74 truck 8/34 interchange [Re: chargerbr549] #2922325
05/14/21 07:01 AM
05/14/21 07:01 AM
moparmarks Offline
moparmarks  Offline
I've had several 72-78 W100/150 and mine were all 4.5 bolt circle.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 74 truck 8/34 interchange [Re: moparmarks] #2922428
05/14/21 12:07 PM
05/14/21 12:07 PM
moparx Offline
moparx  Offline
weren't the trucks with automatic hubs the 4 1/2" bolt pattern ?
beer
Re: 74 truck 8/34 interchange [Re: moparx] #2922445
05/14/21 01:02 PM
05/14/21 01:02 PM
moparmarks Offline
moparmarks  Offline
I had both autos and 4-spd with 4.5 bc.
I thought the larger bc was in the 80's.
I've had a gazillion 72-80 trucks of all sorts and none were the larger bc. I've never messed with the 81-up other than my 92 1-ton.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 74 truck 8/34 interchange [Re: moparx] #2922466
05/14/21 01:36 PM
05/14/21 01:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
up through 74 all w-100 were 5 on 5 1/2
75-79 w-100, w-150 were 5 on 4 1/2
80 on up w-150 were 5 on 5 1/2
Ramcharger/Trailduster 74 -79 5 on 4 1/2
Ramcharger/Trailduster 80 on 5 on 5 1/2
Re: 74 truck 8/34 interchange [Re: NITROUSN] #2922474
05/14/21 02:04 PM
05/14/21 02:04 PM
moparmarks Offline
moparmarks  Offline
I just parted out a 73 W100 and am using the 8.75 in my 78 D100. It is 4.5 bc.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 74 truck 8/34 interchange [Re: moparmarks] #2922478
05/14/21 02:16 PM
05/14/21 02:16 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Had a 74 pickup with 8-1/4 that had a bad axel, took a 8-3/4 out from under a 69 Fury. Knocked the perches of with a big hammer laid em on top then tightened up u-bolts. Got er lined up and welded where they sat. No problems. Can’t remember about the e brake cables.
Re: 74 truck 8/34 interchange [Re: moparmarks] #2922586
05/14/21 07:49 PM
05/14/21 07:49 PM
Between Houston & Galveston TX
SattyNoCar Online happy
SattyNoCar  Online Happy
Unless its from a '71-up B-body wagon which uses the same width rear as a C.
John
Re: 74 truck 8/34 interchange [Re: SattyNoCar] #2922607
05/14/21 08:38 PM
05/14/21 08:38 PM
moparmarks Offline
moparmarks  Offline
Correct which is also the same width as the truck unit.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 74 truck 8/34 interchange [Re: moparmarks] #2922620
05/14/21 09:19 PM
05/14/21 09:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
73 4x4 is 5 1/2. 2wd is 4 1/2. If you had a 4 1/2 in a 73 4x4 some one put it there. You can not put a 4 1/2 on a front with locking hubs. If you do have a 4 1/2 front it is full time and again not correct for a 1973.
Re: 74 truck 8/34 interchange [Re: NITROUSN] #2923256
05/16/21 08:39 PM
05/16/21 08:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is what a factory 72-74 W-100 Power Wagon wheels look like. 5 on 5 1/2.
Re: 74 truck 8/34 interchange [Re: NITROUSN] #2923422
05/17/21 10:56 AM
05/17/21 10:56 AM
moparx Offline
moparx  Offline
agree. locking hubs = 5x5 1/2" bc.
non-locking/"automatic"/full time 4x4 = 5x4 1/2" bc.
beer
Re: 74 truck 8/34 interchange [Re: moparx] #2923714
05/17/21 10:56 PM
05/17/21 10:56 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
I can confirm that at least a 1974 4x4 Dodge 8-3/4 bolt pattern is 5x5.5". Pulled one from a truck in Yuma back in January. Had a 489 case and I traded it off for a car transport. Kicking myself for that one.
Instagram : @5_points_racing
Re: 74 truck 8/34 interchange [Re: JP8] #2923818
05/18/21 08:23 AM
05/18/21 08:23 AM
moparmarks Offline
moparmarks  Offline
Well alrighty then. The 73 I just parted was missing the front axle when I got it so someone maybe changed out the rear. At one time I had probably around 10 truck 8.75 rears and all had 4.5 bc axles.
Love learning new stuff.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 74 truck 8/34 interchange [Re: moparmarks] #2923841
05/18/21 09:31 AM
05/18/21 09:31 AM
scratchnfotraction Offline
for my trucks I have found that they all will fit a truck with a little effort.
the truck housing is 59" flange to flange 43" perch centers for axle under spring. it came with 5 on 4.5 & 5 on 5.5
my 74 w100 had 59" housing 489-3.91 cone suregrip. 5 on 5.5 with 43" perch centers axle under spring
my 74 Chrysler Newport 8 3/4 is also 59" flange to flange 489-3.23 5 on 4.5
any of the 73-74 c-body 8 3/4 housings will replace a truck housing with perch change and axle interchange for wbp size 5 on 4.5 or 5 on 5.5
FYI..
A-body 8 3/4 shares same 43" perch centers for axle over spring
I also tub & lower all of my trucks using different 8 3/4 housings to fit my needs.
A-body housing with Moser large brake offset axles 5 on 4.5 12" rim 4.5 backspace 29x15x15 under my 88-440 truck with a rear shackle flip axle on top of spring
67-C-body/E-body housing 55.5" flange to flange/stock axle 12" rim 6" backspace under my 85 step side 318 truck with shackle flip axle on top of spring
I just picked up a 70 B-body 8 3/4 to use under my 86 w150 build.
Re: 74 truck 8/34 interchange [Re: moparmarks] #2924052
05/18/21 05:17 PM
05/18/21 05:17 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
It blew my mind when I found out with that last 8-3/4 I pulled. I was thinking someone had the axles custom built at some point but I googled it.
Re: 74 truck 8/34 interchange [Re: JP8] #2924058
05/18/21 05:31 PM
05/18/21 05:31 PM
in 85 all the 2x trucks went 5 on 5.5 with the 10 bolt 8 1/4 and 12 bolt 9 1/4 axles being 5 on 5.5 and IIRC the axles do not interchange due to carrier side gears/spider gears.
76 new Yorker front rotors will work on the 82-84 2x truck spindles & 85-93 2x truck spindles when swapping down to 5 on 4.5 to match a 8 3/4 5 on 4.5
