Re: 74 truck 8/34 interchange
[Re: moparx]
#2922445
05/14/21 01:02 PM
05/14/21 01:02 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I had both autos and 4-spd with 4.5 bc. I thought the larger bc was in the 80's. I've had a gazillion 72-80 trucks of all sorts and none were the larger bc. I've never messed with the 81-up other than my 92 1-ton.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2922478
05/14/21 02:16 PM
05/14/21 02:16 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
Had a 74 pickup with 8-1/4 that had a bad axel, took a 8-3/4 out from under a 69 Fury. Knocked the perches of with a big hammer laid em on top then tightened up u-bolts. Got er lined up and welded where they sat. No problems. Can’t remember about the e brake cables.
[Re: moparmarks]
#2922586
05/14/21 07:49 PM
05/14/21 07:49 PM
Posts: 16,828 Between Houston & Galveston TX
SattyNoCar
The truck unit is 1-3/8" wider than the 71-4 B unit. Unless its from a '71-up B-body wagon which uses the same width rear as a C.
John
[Re: SattyNoCar]
#2922607
05/14/21 08:38 PM
05/14/21 08:38 PM
moparmarks
The truck unit is 1-3/8" wider than the 71-4 B unit. Unless its from a '71-up B-body wagon which uses the same width rear as a C. Correct which is also the same width as the truck unit.
[Re: moparmarks]
#2922620
05/14/21 09:19 PM
05/14/21 09:19 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I just parted out a 73 W100 and am using the 8.75 in my 78 D100. It is 4.5 bc. 73 4x4 is 5 1/2. 2wd is 4 1/2. If you had a 4 1/2 in a 73 4x4 some one put it there. You can not put a 4 1/2 on a front with locking hubs. If you do have a 4 1/2 front it is full time and again not correct for a 1973.
[Re: moparx]
#2923714
05/17/21 10:56 PM
05/17/21 10:56 PM
Posts: 168 San Diego
JP8
San Diego
I can confirm that at least a 1974 4x4 Dodge 8-3/4 bolt pattern is 5x5.5". Pulled one from a truck in Yuma back in January. Had a 489 case and I traded it off for a car transport. Kicking myself for that one.
Instagram : @5_points_racing
[Re: JP8]
#2923818
05/18/21 08:23 AM
05/18/21 08:23 AM
moparmarks
Well alrighty then. The 73 I just parted was missing the front axle when I got it so someone maybe changed out the rear. At one time I had probably around 10 truck 8.75 rears and all had 4.5 bc axles. Love learning new stuff.
[Re: moparmarks]
#2923841
05/18/21 09:31 AM
05/18/21 09:31 AM
Posts: 15,487 Florida
scratchnfotraction
for my trucks I have found that they all will fit a truck with a little effort.
the truck housing is 59" flange to flange 43" perch centers for axle under spring. it came with 5 on 4.5 & 5 on 5.5
my 74 w100 had 59" housing 489-3.91 cone suregrip. 5 on 5.5 with 43" perch centers axle under spring
my 74 Chrysler Newport 8 3/4 is also 59" flange to flange 489-3.23 5 on 4.5
any of the 73-74 c-body 8 3/4 housings will replace a truck housing with perch change and axle interchange for wbp size 5 on 4.5 or 5 on 5.5
FYI..
A-body 8 3/4 shares same 43" perch centers for axle over spring
I also tub & lower all of my trucks using different 8 3/4 housings to fit my needs.
A-body housing with Moser large brake offset axles 5 on 4.5 12" rim 4.5 backspace 29x15x15 under my 88-440 truck with a rear shackle flip axle on top of spring
67-C-body/E-body housing 55.5" flange to flange/stock axle 12" rim 6" backspace under my 85 step side 318 truck with shackle flip axle on top of spring
I just picked up a 70 B-body 8 3/4 to use under my 86 w150 build.
[Re: moparmarks]
#2924052
05/18/21 05:17 PM
05/18/21 05:17 PM
JP8
San Diego
Well alrighty then. The 73 I just parted was missing the front axle when I got it so someone maybe changed out the rear. At one time I had probably around 10 truck 8.75 rears and all had 4.5 bc axles. Love learning new stuff. It blew my mind when I found out with that last 8-3/4 I pulled. I was thinking someone had the axles custom built at some point but I googled it.
[Re: JP8]
#2924058
05/18/21 05:31 PM
05/18/21 05:31 PM
scratchnfotraction
Well alrighty then. The 73 I just parted was missing the front axle when I got it so someone maybe changed out the rear. At one time I had probably around 10 truck 8.75 rears and all had 4.5 bc axles. Love learning new stuff. It blew my mind when I found out with that last 8-3/4 I pulled. I was thinking someone had the axles custom built at some point but I googled it. in 85 all the 2x trucks went 5 on 5.5 with the 10 bolt 8 1/4 and 12 bolt 9 1/4 axles being 5 on 5.5 and IIRC the axles do not interchange due to carrier side gears/spider gears. 76 new Yorker front rotors will work on the 82-84 2x truck spindles & 85-93 2x truck spindles when swapping down to 5 on 4.5 to match a 8 3/4 5 on 4.5
