440 VAPOR SEPARATOR. #29228
08/06/06 08:26 AM
08/06/06 08:26 AM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
i upgraded my car to a 3/8 fuel line with a 1/4 return line,bought a 440 vapor seperator from year one.the car started running bad like it was staving for fuel,now it wont start unless you put gas directly into the carb,is my fuel pump bad or is the vapor seperator keeping fuel from my carb??
Re: 440 VAPOR SEPARATOR. [Re: TB3CUDA] #29229
08/06/06 08:37 AM
08/06/06 08:37 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would put a 3/8 in line filter in place of thes the new separator for test purpose. You'll have to plug the return hose during the test. Maybe it's sending too much back to the tank.
Re: 440 VAPOR SEPARATOR. [Re: TB3CUDA] #29230
08/06/06 09:05 AM
08/06/06 09:05 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
I bought a vapor separator from YO several years ago... same problem. You probably only have about 2 lbs. of fuel pressue right now.
The smaller fitting for the return is missing an internal restrictor. In other words... you got junk... return it if they let you.
From what I remember - the internal restrictor in that fitting / line is supposed to be about .040. but don't quote me.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: 440 VAPOR SEPARATOR. [Re: TB3CUDA] #29231
08/06/06 11:04 AM
08/06/06 11:04 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
I have an original separator on my car and no problems. If you can't see a restriction in the return stem of the separator you can just plug the thing completely, or perhaps braze it closed and then drill an .040 hole into it.
Best would be to return it and let the vendor know they are selling something that doesn't function, but that will probably cost you shipping and restocking fees to the point where it is just not worth it.
Re: 440 VAPOR SEPARATOR. [Re: Quikshft] #29232
08/06/06 12:31 PM
08/06/06 12:31 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
so how can i run a return line back to my tank without this seperator??would a fuel regualot work with a return line??or would i be better off putting my 5/16 sending unit with no return line back in my tank??
Re: 440 VAPOR SEPARATOR. [Re: TB3CUDA] #29233
08/06/06 01:56 PM
08/06/06 01:56 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I ran into the same issue after adding my new 3/8" sending unit and then buying a 426/440 vapor separator off of YO.
I fixed it buy going to my local NAPA and buying their Gold #3054 filter/separator. It is an in-line fuel filter with a return line off of the side of it for $6. Then just clamp on your return line.
http://www.napaonline.com/MasterPages/NO...l+Filter+(Gold)
Re: 440 VAPOR SEPARATOR. [Re: YO7_A66] #29234
08/06/06 02:23 PM
08/06/06 02:23 PM
808CUDA Offline
808CUDA  Offline
Hey Y07 A66!!!
thanks for that tip!
I was wondering the same thing, if they made such a filter!
Does it really matter where you install it? DOes it have to be mounted vertically where it originally sits on a 440+6 or can I mount it horizontally on top with the nipple facing upwards?
Thanks!
Gil
P.S. They don't make a clear one do they?
Re: 440 VAPOR SEPARATOR. [Re: 808CUDA] #29235
08/06/06 02:32 PM
08/06/06 02:32 PM
808CUDA Offline
808CUDA  Offline
Just realized one dilemma...it has 5/16" inlet and outlet...
I'll check the store out and see if they have a 3/8"
Gil
Re: 440 VAPOR SEPARATOR. [Re: 808CUDA] #29236
08/06/06 02:48 PM
08/06/06 02:48 PM
808CUDA Offline
808CUDA  Offline
just searched on NAPA's site, found a #3041 which has 3/8" nipples.
Thanks for the link!
gil
Re: 440 VAPOR SEPARATOR. [Re: 808CUDA] #29237
08/06/06 04:06 PM
08/06/06 04:06 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
thanks for the napa info,i will be down there monday,and just think i paid $65.00 for that black piece of junk from year one.
Re: 440 VAPOR SEPARATOR. [Re: 808CUDA] #29238
08/06/06 04:54 PM
08/06/06 04:54 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
808:
""just searched on NAPA's site, found a #3041 which has 3/8" nipples""
Good note, I didn't know they had one with 3/8 nipples!!
I would guess that the vapor will rise to the top and the filter would have to stand vertical with the 1/4" return to the top.
TB3:
Yep, my $65 YO unit is in my attic now. I was told by another member that they are making one of the holes in the piece too large allowing the fuel to run back thru to the tank. Too bad because they "look" like nice pieces. I bought mine two years prior to actually installing it so I couldn't send it back.
Re: 440 VAPOR SEPARATOR. [Re: YO7_A66] #29239
08/06/06 05:10 PM
08/06/06 05:10 PM
Thanks for the info and the NAPA part number - I have been planning to upgrade the fuel system on the Volaré to 3/8" line and this was one piece of the puzzle that was hard to find.
440shorty
Re: 440 VAPOR SEPARATOR. [Re: 808CUDA] #29240
07/21/07 10:02 PM
07/21/07 10:02 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
gil
Here's a big bump.
I just bought one of the aforementioned filter/separators. Unlike the original peice, the vapor return nipple is on the outlet (top) side.
I have one installed on my car and it's not working. I'm not getting much fuel to the carb.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 440 VAPOR SEPARATOR. [Re: YO7_A66] #29241
07/21/07 10:09 PM
07/21/07 10:09 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
TB3:
... I thought Y-1 will take any part back with no timeframe on the return ??? ...... Or did they do away with that policy ???
Re: 440 VAPOR SEPARATOR. [Re: 471Magnum] #29242
07/23/07 02:39 PM
07/23/07 02:39 PM
Groton, MA.
BHuey Offline
BHuey  Offline
Groton, MA.
I also tried a NAPA 3041, with the nipple on the top. It did have an orifice installed looked like about .040 but it didn't work. It channeled fuel out the nipple.
70 Challenger R/T Conv. 66 Vette 427 Coupe 61 Vette FI Roadster
Re: 440 VAPOR SEPARATOR. [Re: 808CUDA] #29243
07/23/07 03:28 PM
07/23/07 03:28 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Gil
I have an original on my Kuda, and it IS 5/16". From the fuel pump to the carb that's all Ma Mopar used was 5/16".It's a fact and it's all you'll need too.
Re: 440 VAPOR SEPARATOR. [Re: Kudakidd] #29244
07/23/07 04:29 PM
07/23/07 04:29 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
This is an moldee oldee.
That's funny, the Y1 pieces were junk 10 years ago as well as I ran into the same problem on my six pack car.
I went with Bill Allphin on the last one. Same price but it works. http://amhightechauto.com/
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
