Re: Help with cam ID
[Re: MrMayhem]
#2921679
05/12/21 01:55 PM
05/12/21 01:55 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
https://www.summitracing.com/parts/cca-21-248-4/make/dodgeComp Cams Magnum series solid FT The 294S-10 engraved on it gives it away. Nice hot street/strip cam in my opinion.
[Re: an8sec70cuda]
#2921740
05/12/21 04:11 PM
05/12/21 04:11 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
Wow, that was fast! Thank you on the info, that actually helps a lot. I have a 10:1 440 short block and ported Sidewinder heads and 1.6 roller rockers that should get the lift into the .550 range. I think I might slam that cam in that motor, it should work great with a 3k converter in my Duster with 3.91's....
