Help with cam ID #2921675
05/12/21 01:49 PM
05/12/21 01:49 PM
Oklahoma City, Oklahoma
MrMayhem Offline OP
MrMayhem  Offline OP
I have a mystery Solid cam that was pulled from a high effort 440 drag truck built about 20 years ago... I friend who was cleaning his garage passed this down to me knowing I have several big block mopar builds in process. He could not recall the make or specs of the cam other than thinking it might be a Crane Solid cam. I measured the lift to be at 525 at the valve. The owner/racer claimed his 82 d100 ran low 11's with this cam. Any how, here are a few pics of the markings on the cam... can anyone decipher the numbers? Any feedback will be helpful in deciding if this is worth saving or using.
Re: Help with cam ID [Re: MrMayhem] #2921679
05/12/21 01:55 PM
05/12/21 01:55 PM
an8sec70cuda Offline
https://www.summitracing.com/parts/cca-21-248-4/make/dodge
Comp Cams Magnum series solid FT
The 294S-10 engraved on it gives it away.
Nice hot street/strip cam in my opinion. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Help with cam ID [Re: an8sec70cuda] #2921740
05/12/21 04:11 PM
05/12/21 04:11 PM
MrMayhem Offline OP
MrMayhem  Offline OP
Wow, that was fast! Thank you on the info, that actually helps a lot. I have a 10:1 440 short block and ported Sidewinder heads and 1.6 roller rockers that should get the lift into the .550 range. I think I might slam that cam in that motor, it should work great with a 3k converter in my Duster with 3.91's....
