Re: Cam for 505 stroker [Re: General 68] #2921485
05/12/21 02:16 AM
05/12/21 02:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a rev-limiter on my 505. Easy to spin them past 6,000 RPM with a manual trans.
Re: Cam for 505 stroker [Re: 451Mopar] #2921570
05/12/21 11:06 AM
05/12/21 11:06 AM
Norway
General 68 Offline OP
Norway
Yes. I have one now.
For previous poster: European 98 octane. Should be the same as premium in the US.
Re: Cam for 505 stroker [Re: General 68] #2921572
05/12/21 11:09 AM
05/12/21 11:09 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Wonder how they converts?
I thought there was better high octane gas in Europe than US ?
Re: Cam for 505 stroker [Re: autoxcuda] #2921595
05/12/21 11:51 AM
05/12/21 11:51 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
In Europe they use the RON rating. In the US we use the average of the RON and MON ratings. 98 octane in Europe is roughly equivalent to 93 rating here.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Cam for 505 stroker [Re: General 68] #2921680
05/12/21 01:57 PM
05/12/21 01:57 PM
NY
B1duster Offline
B1duster  Offline
NY
So no problem with detonation using that
Hughes 232/236-110 ?
Re: Cam for 505 stroker [Re: B1duster] #2921805
05/12/21 06:33 PM
05/12/21 06:33 PM
Norway
Norway
No, I have not experienced any detonation. It runs nice and smooth. Idle is quite smooth at around 900 rpm and drivability with a manual trans is good for what this is. Just have to baby the throttle to avoid the tires from squeeling from a dead stop.
Re: Cam for 505 stroker [Re: 3hundred] #2921821
05/12/21 07:14 PM
05/12/21 07:14 PM
So Cal
So Cal
I think there is one gas station within a 10 miles radius of me that has 93 octane. Everything else is 91 octane California blend tops.
93 would definitely help.
Re: Cam for 505 stroker [Re: General 68] #2922247
05/13/21 09:26 PM
05/13/21 09:26 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Looking for a street friendly hydraulic flat tappet Cam for a 440/512 stroker.
CR 9,8:1, Stage 4 iron heads, 1,6 rockers, Indy dual plane intake, 2" headers, 3" x-pipe.
Manual trans
Want lots of low end torque and vacuumn for power brakes.
Heavy car, 4200lb, mostly street driven.
Any experience with Hughes Engines cams? Looking at the SEH2832BL-10 or
SEH3236BL-10 or Are they too much?
i used the seh3236bl3-14 [ 114 lobe sep- ] installed @ 110 C/L iron 915's stock---- 10-25-1 compression . stock 6 pack w factory dist . manifolds ... hp was 522 peak @ 5500rpm torque was 586lbs@5200rpm... it was lean by a good bit too..... the 114 l/s makes it idol near stock @ 900 rpm.. very smooth barely notice a lope ... torque is over 500 @3500rpm....................
Re: Cam for 505 stroker [Re: ek3] #2922316
05/14/21 03:16 AM
05/14/21 03:16 AM
Norway
Norway
Nice numbers! Unported heads and manifolds too!?👍
What size engine is it?
Re: Cam for 505 stroker [Re: General 68] #2922535
05/14/21 04:47 PM
05/14/21 04:47 PM
E
ek3 Offline
ek3  Offline
E
440-512 440 source kit-hughes cam and rocker system. 915 w/ large valves , bowl job, iron 6 pack intake, fact manifolds, stuska dyno.............really nice machine work ! extra time spent to get tight clearances and exceptional ring sealing and correcting all geometry. runs out of power quick but, it has a big bottom..
