Great answer for stripped threads...Timesert inserts #29187
08/02/06 06:14 PM
08/02/06 06:14 PM
Northern N.J.
hemi_doug Offline OP
Northern N.J.
I found a great source for fixing stripped threads. They are inserts made by a company called Timesert . The kit cost around 50.00 and came with 5 inserts, if you need more then that, you can order them at the same time. The kit comes with the proper size drill, countersink, tap and insert tool. It was the only fix that I found for small thread sizes (I needed 10/32). It took me about 15 minutes to replace 8 threaded holes. They also have kits for stripped out oil plugs. Check them out if you have some stripped holes that you need to fix. I think they are a better answer then heli-coils.
71 440-6 4spd & 69 Hemi 4spd
Re: Great answer for stripped threads...Timesert inserts [Re: hemi_doug] #29188
08/02/06 06:26 PM
08/02/06 06:26 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Looks like they should work fine.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Great answer for stripped threads...Timesert inserts [Re: hemi_doug] #29189
08/02/06 06:42 PM
08/02/06 06:42 PM
santa rosa,ca
RTDude Offline
RTDude  Offline
santa rosa,ca
Been using them for years without a problem,love 'em!
Re: Great answer for stripped threads...Timesert inserts [Re: RTDude] #29190
08/03/06 07:34 AM
08/03/06 07:34 AM
Northern N.J.
Northern N.J.
The worked like magic for replacing stripped threads in a Carter carb. Beats having to replace the carb body for sure.
Re: Great answer for stripped threads...Timesert inserts [Re: hemi_doug] #29191
08/03/06 09:23 AM
08/03/06 09:23 AM
PA
70Duster Offline
70Duster  Offline
PA
These work real well. As a matter of fact, the use of Timeserts is the only GM approved method for repairing the failed headbolt threads in the aluminum Northstar blocks.
Re: Great answer for stripped threads...Timesert inserts [Re: 70Duster] #29192
08/03/06 09:29 AM
08/03/06 09:29 AM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
Timesert inserts are also standard practice for stripped spark plug holes in Ford modular engines.
Steve
Someday I'll have another C-body.
Re: Great answer for stripped threads...Timesert inserts [Re: SteveS] #29193
08/03/06 09:47 AM
08/03/06 09:47 AM
Bern, Switzerland
6o4o Offline
6o4o  Offline
Bern, Switzerland
hmm that looks to me like a helicoil or what's different?
Re: Great answer for stripped threads...Timesert inserts [Re: 6o4o] #29194
08/03/06 09:55 AM
08/03/06 09:55 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
its a solid bushing with a lip to prevent it from screwing into the hole with the bolt
Re: Great answer for stripped threads...Timesert inserts [Re: aarcuda] #29195
08/03/06 12:05 PM
08/03/06 12:05 PM
amxautox Offline
amxautox  Offline
A helicoil is merely a 'special wire' wound in the shape of threads. To be as basicly as possible.
Tom
author unknown
Re: Great answer for stripped threads...Timesert inserts [Re: hemi_doug] #29196
08/03/06 01:09 PM
08/03/06 01:09 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I like those and here in the shop we use Keenserts, a simlar concept.
Keensert Supplier
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Great answer for stripped threads...Timesert inserts [Re: RoadRunner] #29197
08/03/06 01:47 PM
08/03/06 01:47 PM
Keenserts..
The toughest I've ever used. I repaired pulled threads on a D-9 dozer final drive hsg. The original threaded holes held the ripper on, and were pulled out...
Keenserts fixed the problem, and the ripper stayed put.
Re: Great answer for stripped threads...Timesert inserts #29198
08/03/06 03:13 PM
08/03/06 03:13 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
Timeserts are a required tool for Gm dealers.They work for all aluminum block and head repairs,head bolts,mains,etc.They work great. Chris
