Great answer for stripped threads...Timesert inserts
#29187
08/02/06 06:14 PM
08/02/06 06:14 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
I found a great source for fixing stripped threads. They are inserts made by a company called Timesert . The kit cost around 50.00 and came with 5 inserts, if you need more then that, you can order them at the same time. The kit comes with the proper size drill, countersink, tap and insert tool. It was the only fix that I found for small thread sizes (I needed 10/32). It took me about 15 minutes to replace 8 threaded holes. They also have kits for stripped out oil plugs. Check them out if you have some stripped holes that you need to fix. I think they are a better answer then heli-coils.
71 440-6 4spd & 69 Hemi 4spd
Re: Great answer for stripped threads...Timesert inserts
[Re: hemi_doug]
#29188
08/02/06 06:26 PM
08/02/06 06:26 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Looks like they should work fine.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: RTDude]
#29190
08/03/06 07:34 AM
08/03/06 07:34 AM
hemi_doug
Northern N.J.
The worked like magic for replacing stripped threads in a Carter carb. Beats having to replace the carb body for sure.
[Re: 70Duster]
#29192
08/03/06 09:29 AM
08/03/06 09:29 AM
Posts: 2,262 Groveland, MA
SteveS
Groveland, MA
Timesert inserts are also standard practice for stripped spark plug holes in Ford modular engines.
Steve
Someday I'll have another C-body.
[Re: aarcuda]
#29195
08/03/06 12:05 PM
08/03/06 12:05 PM
amxautox
A helicoil is merely a 'special wire' wound in the shape of threads. To be as basicly as possible.
Tom
author unknown
[Re: hemi_doug]
#29196
08/03/06 01:09 PM
08/03/06 01:09 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I like those and here in the shop we use Keenserts, a simlar concept. Keensert Supplier
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#29197
08/03/06 01:47 PM
08/03/06 01:47 PM
Keenserts.. The toughest I've ever used. I repaired pulled threads on a D-9 dozer final drive hsg. The original threaded holes held the ripper on, and were pulled out... Keenserts fixed the problem, and the ripper stayed put.
