Found the culprit stranding me Sunday #2918535
05/04/21 04:50 PM
05/04/21 04:50 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Couldnt make the semis Sunday. Had won the previous rd. But now had no forward gears. Time to upgrade that stock 1965 planetary.
Doug
Re: Found the culpritbeing straded [Re: dvw] #2918540
05/04/21 04:57 PM
05/04/21 04:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you race often enough and long enough you WILL break parts whiney shruggy
How do I know that whistling grin
Re: Found the culpritbeing straded [Re: dvw] #2918545
05/04/21 05:04 PM
05/04/21 05:04 PM
NC
440Jim Offline
440Jim  Offline
NC
That explains it...
Just be sure and get the planetary with the splines that match the year of your shaft.
Spline pressure angles were:
'62 to '75: 45º
'76 to '93: 37.5º
'94 and later: 30º
The pressure angle is half the included angle (90°, 75°, 60°).
Re: Found the culpritbeing straded [Re: dvw] #2918632
05/04/21 08:27 PM
05/04/21 08:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I see steel in your future.....
Re: Found the culpritbeing straded [Re: J_BODY] #2918656
05/04/21 09:12 PM
05/04/21 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug.. minor issue you'll be running in short order..good luck
wave
Re: Found the culpritbeing straded [Re: MR_P_BODY] #2918665
05/04/21 09:23 PM
05/04/21 09:23 PM
Casper, WY
W
Wax Offline
Wax  Offline
W
Casper, WY
Looks familiar. Had that happen to me at MATS many years ago. Took out the transmission as well as the rear end. That was the only year that I did NOT remove the transmission and have it rebuilt. First car to be taken off the track on a rollback.
Re: Found the culpritbeing straded [Re: Wax] #2918671
05/04/21 09:43 PM
05/04/21 09:43 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
When I was getting the trans built for my 493 I took the builder a truck trans for a core and asked him if he thought it would have 4 pin planets in it and he said it didn't matter.
He said when him and his partner were running their AA/SS car, they took out 2 of the 4 pinions and never had a pinion failure. They all did what yours did.
Kevin
Re: Found the culpritbeing straded [Re: Twostick] #2918674
05/04/21 10:02 PM
05/04/21 10:02 PM
PA
moparacer Offline
moparacer  Offline
PA
How many passes was on that set? Making too much power now....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Found the culpritbeing straded [Re: moparacer] #2918688
05/04/21 10:37 PM
05/04/21 10:37 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I caught it one time before on inspection. Just about stripped. Probably about 350 passes I'd have to look. And yes this is the 1st year I haven't pulled it down to inspect, 18 passes into the season. Itll be ready for my next race on 2 weeks. The pan got caved in about 1/4" from the big wheelie. I'll pull it and bump it out. Funny the bottom of the diaper is fine.
Doug
Re: Found the culpritbeing straded [Re: dvw] #2918849
05/05/21 12:18 PM
05/05/21 12:18 PM
central il.
second 70 Offline
second 70  Offline
central il.
Blame it on the new Holley's power gain. Lol
Re: Found the culpritbeing straded [Re: second 70] #2918868
05/05/21 12:56 PM
05/05/21 12:56 PM
PA
moparacer Offline
moparacer  Offline
PA
Wow when you are caving the trans pan in you are landing HARD...
Would be the perfect time to switch to a....Ahem...Cough Cough....
Glide. fan
Re: Found the culpritbeing straded [Re: moparacer] #2918882
05/05/21 01:56 PM
05/05/21 01:56 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Glide. fan
No, the cave in is the oil pan. Funny thing it didn't rip the diaper up.
Doug
Re: Found the culpritbeing straded [Re: dvw] #2918925
05/05/21 03:46 PM
05/05/21 03:46 PM
an8sec70cuda Offline
Wow, glad it's a relatively easy fix! I'm surprised it's lasted as long as it has. My trans guy recommended a steel planetary setup for me once I surpassed the 650 hp or so range.
Good luck w/ it Doug...looking forward to seeing how those new carbs work out for you.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Found the culpritbeing straded [Re: an8sec70cuda] #2918941
05/05/21 04:38 PM
05/05/21 04:38 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Awww.. it's not that bad. Can't you just braze it back on to the output shaft and call it good?
Re: Found the culpritbeing straded [Re: dizuster] #2918962
05/05/21 05:11 PM
05/05/21 05:11 PM
whistling grin up
Re: Found the culpritbeing straded [Re: Cab_Burge] #2919166
05/06/21 02:14 AM
05/06/21 02:14 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
The fact that it lasted as long as it did is amazing.....must be diff alum used in '65 wink
Re: Found the culpritbeing straded [Re: moparacer] #2919233
05/06/21 10:48 AM
05/06/21 10:48 AM
gregsdart Offline
gregsdart  Offline
Glide. fan
What, and give up all the fun? Wheelies are FUN!
Re: Found the culpritbeing straded [Re: gregsdart] #2919234
05/06/21 10:52 AM
05/06/21 10:52 AM
gregsdart Offline
gregsdart  Offline
I had mine fail that way twice. The second failure i found the dana 60 had slipped on the axle tubes. Funny, those aluminum parts didn't appreciate a 30 degree pinion angle😁
Re: Found the culpritbeing straded [Re: dvw] #2919361
05/06/21 01:55 PM
05/06/21 01:55 PM
PA
moparacer Offline
moparacer  Offline
PA
Quote
Mine did last year. I had a guy near me who builds tarps sew it back up. I got rid of the center sump hanging down thing and put the Milodon flat bottom pan on mine the other week .Much more stable oil pressure. I hit the pan now and I am looking for a new car lol.
Quote
I know but sooner or later they get expensive, and if you are shoe polish racing they cost you win lights...
