440-6 idle adjustment #291701
04/18/09 09:44 AM
04/18/09 09:44 AM
Anonymous OP
Anonymous OP
I am advised to try leaning out my idle a little to rid the backfire on deacceleration. Do I turn the adjustment screws in or out to lean it out? Also what is a standard for the outboards? Holley tech thought maybe 1/8 turn out but was not sure.
Re: 440-6 idle adjustment #291702
04/18/09 10:12 AM
04/18/09 10:12 AM
Colorado
hemiluver Offline
hemiluver  Offline
Colorado
I think on those carbs its out to lean because your adding air not fuel
Re: 440-6 idle adjustment [Re: hemiluver] #291703
04/18/09 10:22 AM
04/18/09 10:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
are yuo sure you don't have a tiny exhaust leak somewhere? Especially if it's only out one side.
Re: 440-6 idle adjustment #291704
04/18/09 12:45 PM
04/18/09 12:45 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
all 3 carbs are clockwise to lean, counter clockwise to make richer.
Re: 440-6 idle adjustment #291705
04/19/09 03:44 PM
04/19/09 03:44 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
any luck?
Re: 440-6 idle adjustment [Re: hemiluver] #291706
04/19/09 08:26 PM
04/19/09 08:26 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Idle screws add a mixture of air and fuel.
A lean idle should not cause a backfire. Look elsewhere for your problem. Check the normal causes first before blamming the carbs. An exhaust leak or fouled spark plug are the most common causes.
