Re: Lunati Rollers to Isky or Crower
[Re: sogtx]
#2914961
04/25/21 10:10 PM
04/25/21 10:10 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
No but it would make my day if they were within a thousandth . Lol Im sure ill need pushrods . Also - just curious also if anyone has experienced the crowers . Lot of innernet complaints of morells & Lunatis . Nicest i have used are Crane Ultra pro’s
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: sogtx]
#2939235
07/03/21 08:18 AM
07/03/21 08:18 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Buy a lifter with the same pushrod cup ht and you will be fine no changing pushrods.Look up tjis info about your current lifter. My Lunatis seemed a little loud to me . Pulled apart for inspection Anyone swap from a $450 dollar lifter to an $850 dollar lifter and note pushrod difference ? Still gonna check But .. want to see what this project will end up costing.
Thanks !
Lifter tech
[Re: sogtx]
#2940107
07/05/21 11:28 AM
07/05/21 11:28 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
What brand did you buy and use?
[Re: Cab_Burge]
#2941690
07/09/21 11:56 PM
07/09/21 11:56 PM
Posts: 781 wine country
8urvette
wine country
What brand did you buy and use? yes inquiring minds need to know!!!!
[Re: sogtx]
#2968056
09/28/21 07:19 AM
09/28/21 07:19 AM
Posts: 16,923 NC
440Jim
NC
Fyi pushrod lengths were perfect as was .. no changes were necessary Both landed on stems exactly in same spot! Thanks for letting us know the Crower and Lunati have the same lifter seat height. Can you measure your old ones and tell us what the actual numbers are? Body height, seat depth, etc. My notes say, Crower 66233-16 or with H seat height 1.34”, 122g, 0.812” bearing. With pushrod oiling. But I don't know how they define "seat height" The Comp lifters seem to define it as put a 5/16 ball in the seat and measure from the top of the ball to the bottom of the lifter.
[Re: sogtx]
#2968057
09/28/21 07:20 AM
09/28/21 07:20 AM
Posts: 16,923 NC
440Jim
NC
Oops This thread flew right by me .
. New Howards lifters are definitely quieter ! Switched back to 10/30 oil
They are Nice ! Are the Howards the same lifter seat height as the Crower and Lunati?
