340 Tuning advice #291431
04/17/09 10:28 PM
04/17/09 10:28 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Hey guys I'm trying to get the little 340 in my challenger running a little better. Its a completely stock 340 with headers and an Edelbrock carb (I've never touched an Edelbrock carb before this one). The car idles smooth and runs/drives good at part throttle but when you go full throttle it hesitates ...sometimes pops, sputters then gradually takes off. The exhaust smells extremely rich at full throttle but generally pops and sputters are caused by a lean condition so I'm confused.
I checked the timing and its set at about 34. I took the carb apart and it had some junk in it from sitting so I cleaned it all up and re-assembled. Helped the driveability quite a bit. The carb tuning I've done so far includes; installed an electric choke (the car starts right up when cold now); set the idles; moved the pump shot up to the largest slot which helped with wide open hesitation but its still there. The car pulls great vacuum and doesnt have an intake leak as it stalls instantly if you cover the carb with your hand.
Anyway if anyone could offer some Eddy carb tuning suggestions ...I would be gratefull.
One other problem ...the car starts right up when cold or when shut off for a few seconds it'll fire right back up but if the car sits for a few minutes (like running into a store) the car is difficult to start. Usually have to hold the throttle part open and crank away to start it up. I'm thinking the gas may evaporating? The fuel line is cobbled crap right now so that is on my list too but doesnt seem like that would cause these troubles.
So far I'm thinking plugs (what would you guys recommend), good plug wires, fuel line from mech pump to carb and re-jetting (not sure where to start though). Whaddaya guys think?
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 340 Tuning advice [Re: 69dart] #291432
04/17/09 11:02 PM
04/17/09 11:02 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Shaun, Sounds like carb is leaking into intake when you park it and it puddles fuel and floods it out when warm. Floats could be too high or base could have leak. Also,make sure the vacuum advance works correctly and unless distributor has been curved , just set timing to factory specs. I had a 340 Dart years ago and the plugs would glaze up and pop like a lean pop. Put in new plugs and problem solved for a while. That was with champion n9y plugs. I run autolite 65's in the Cuda with no issues at all, but I don't have factory ignition. I have a Eddie 500 laying around if you want to try it. Not sure how good it is, a friend gave it to me and said it worked fine. Tell Megan and Kids hi!
Re: 340 Tuning advice [Re: 69dart] #291433
04/17/09 11:05 PM
04/17/09 11:05 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
You sound like your way fat on the jets. It will pop if its fat, as for your hard starting after sitting sounds like you have fuel leaking into the intake and flooding it out. Run the car for a while and shut it down. Pull the air cleaner off and see if its leaking fuel.....Hope this helps...Phill
Re: 340 Tuning advice [Re: 9 Sec Phill] #291434
04/18/09 09:58 PM
04/18/09 09:58 PM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
What size eddy? 600 or 750?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: 340 Tuning advice [Re: Fishmarket] #291435
04/18/09 10:43 PM
04/18/09 10:43 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Its the 1405 so google says the carb is a 600.
Timing advance works well as it doesnt have much advance at idle but comes in to 34 once revved up.
Since I only have one good arm right now I put the wife to work. I picked up an Eddy Performer at the Winter Classic for $50 and we went ahead and installed it today.
I cant believe how much the factory cast iron intake piece weighed. That thing has to weigh every bit of 75 lbs. The swap went really smooth.
Also installed some new plug wires and rebuilt the carb. The floats in the carb were way off and there was some more junk under needle seat in the screen.
Took about 8 hours but the car fired right back up and I didnt see any leaks. I haven't driven it yet but momma says its like a new car.
So maybe we'll grab some jets and take it out to test N' tune tomorrow and see what it'll do.
Thanks Dan ...did you guys enjoy the weather KK?
68 Dart - 340
66 Belvedere - 400
Re: 340 Tuning advice [Re: 69dart] #291436
04/19/09 01:22 PM
04/19/09 01:22 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Yea Kil-kare was great, been there 3 weeks in a row. Payout is very good , and they had 282 cars and lots of spectators last night. Staff very friendly. Track has hook, very very consistant 60 fts both cars. Not used to that!
Re: 340 Tuning advice [Re: 69dart] #291437
04/19/09 01:43 PM
04/19/09 01:43 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Unplug the vac advance and set total timing to 34/38. then plug in vac. advance andsee how much total is with it hooked up. If more than 45 deg put a 3/32 allen in vac adv hose hole and turn it ccw a turn and a half and recheck. Also the vac adv hose should be hooked to the port on carb that has vac. present while idleing.
Re: 340 Tuning advice [Re: qwkmopardan] #291438
05/10/09 10:27 PM
05/10/09 10:27 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
So I finally unhooked the vacuum advance and checked the timing. It only had about 15 degrees. So I cranked it up to 37 total and left the vacuum advance unhooked but plugged the carb port. Holy Cow that was the problem ...the car screams now. Drove it all over this weekend ...now it'll lay a patch as far as you want to go. It seems to have helped the hard starting issue after sitting for a few minutes as well.
I tried plugging the vacuum back in but it pushed the timing to over 50 degrees so I'm going to leave it unhooked for now. It starts at about 25 degrees and goes to 37 when revved up right now. It still cranks ok so I'm not sure of a reason to hook the vacuum advance back up.
Now I just have to find a kickdown lickage that works. I fiddled with the one that came on the car for hours but it just doesnt fit. Along time ago I put a carb spring on the kickdown linkage to keep some tension on it and it works pretty decent. The car always shifts about 3000 RPM when in Drive which actually is about right for driving around. Just have to use the slapstick when its time to get on it.
Re: 340 Tuning advice [Re: 69dart] #291439
05/11/09 12:43 PM
05/11/09 12:43 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If you have a fuel percolation problem like most Edelbrock carbs do these work well:
http://store.summitracing.com/partdetail...mp;autoview=sku
If you are hooking vacuum up to a ported source on the carb you should not be getting any additional advance when you hook it up.
Re: 340 Tuning advice [Re: qwkmopardan] #291440
05/12/09 07:22 AM
05/12/09 07:22 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Why only 45 total adv with the vac adv??
Most engine will easily run @52 degrees total when tuned properly...
Re: 340 Tuning advice [Re: 69dart] #291441
05/12/09 07:27 AM
05/12/09 07:27 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That's because your likely plugging vacuum into the wrong port. Probably one of the most common mistakes.
Re: 340 Tuning advice [Re: Dodgem] #291442
05/12/09 07:33 AM
05/12/09 07:33 AM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Huh? With the vacuum plugged in it had 37 ...unplugged it had 15.
So I left it unplugged but bumped the mechanical advance to 37 and it runs great.
It was plugged into the front port on the Edelbrock carb.
What are the benefits to the extra vacuum advance at 45-50. Better MPG's or cruising?
Re: 340 Tuning advice [Re: 69dart] #291443
05/12/09 07:36 AM
05/12/09 07:36 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
One port is manifold vacuum and the other is ported vacuum. The ported vacuum only draws air during part throttle and stops sucking at idle. Manifold will be strongest at idle and decrease as RPMs build.
Re: 340 Tuning advice [Re: 69dart] #291444
05/12/09 08:06 AM
05/12/09 08:06 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That's right idle vacuum was pulling the cruise advance on. but under heavy load and WOT there is little or no vacuum so it falls to your incorrectly set total. thus the hesitation and popping and all round poor WOT performance and yes the vacuum advance is a crude cruising gas mileage enhancer. Under light throttle (low cylinder pressure) the ported vacuum will have vacuum as it is exposed to manifold vacuum and allows more timing then normally unable to help carry the motor a bit this giving a little (and I mean little) more gas mileage.
when under heavier load low vacuum occures and it is taken back out of the equation and your total mechanical is all you have.
I personally think trying to mix vacuum advance (on the right ported vacuum) has no real place on a performance car.
Re: 340 Tuning advice [Re: Dodgem] #291445
09/04/09 07:56 AM
09/04/09 07:56 AM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
So the fuel pump went out on the Chally at the Mopar Nats and we actually had to get a tow home from Heath on the flatbed. Anyway I replaced the stock fuel pump with an Edelbrock 110 pump 6 psi. Now the car seems to be running really rich. You can smell it idling and driving. I'm going to play with the carb but how would changing the fuel pump effect idle and driving?
Re: 340 Tuning advice [Re: 69dart] #291446
09/04/09 08:16 AM
09/04/09 08:16 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Float level is too high now.
