Re: 340 Tuning advice
[Re: qwkmopardan]
#291438
05/10/09 10:27 PM
05/10/09 10:27 PM
Posts: 1,412 Johnstown
69dart
Johnstown
So I finally unhooked the vacuum advance and checked the timing. It only had about 15 degrees. So I cranked it up to 37 total and left the vacuum advance unhooked but plugged the carb port. Holy Cow that was the problem ...the car screams now. Drove it all over this weekend ...now it'll lay a patch as far as you want to go. It seems to have helped the hard starting issue after sitting for a few minutes as well. I tried plugging the vacuum back in but it pushed the timing to over 50 degrees so I'm going to leave it unhooked for now. It starts at about 25 degrees and goes to 37 when revved up right now. It still cranks ok so I'm not sure of a reason to hook the vacuum advance back up. Now I just have to find a kickdown lickage that works. I fiddled with the one that came on the car for hours but it just doesnt fit. Along time ago I put a carb spring on the kickdown linkage to keep some tension on it and it works pretty decent. The car always shifts about 3000 RPM when in Drive which actually is about right for driving around. Just have to use the slapstick when its time to get on it.
[Re: qwkmopardan]
#291440
05/12/09 07:22 AM
05/12/09 07:22 AM
Posts: 2,468 Answering the call of the wild
ThermoQuad
Unplug the vac advance and set total timing to 34/38. then plug in vac. advance andsee how much total is with it hooked up. If more than 45 deg put a 3/32 allen in vac adv hose hole and turn it ccw a turn and a half and recheck. Also the vac adv hose should be hooked to the port on carb that has vac. present while idleing.
Why only 45 total adv with the vac adv??
Most engine will easily run @52 degrees total when tuned properly...
[Re: 69dart]
#291441
05/12/09 07:27 AM
05/12/09 07:27 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
That's because your likely plugging vacuum into the wrong port. Probably one of the most common mistakes.
[Re: 69dart]
#291444
05/12/09 08:06 AM
05/12/09 08:06 AM
Dodgem
Ontario, Canada
It was plugged into the front port on the Edelbrock carb.
What are the benefits to the extra vacuum advance at 45-50. Better MPG's or cruising?
That's right idle vacuum was pulling the cruise advance on. but under heavy load and WOT there is little or no vacuum so it falls to your incorrectly set total. thus the hesitation and popping and all round poor WOT performance and yes the vacuum advance is a crude cruising gas mileage enhancer. Under light throttle (low cylinder pressure) the ported vacuum will have vacuum as it is exposed to manifold vacuum and allows more timing then normally unable to help carry the motor a bit this giving a little (and I mean little) more gas mileage. when under heavier load low vacuum occures and it is taken back out of the equation and your total mechanical is all you have. I personally think trying to mix vacuum advance (on the right ported vacuum) has no real place on a performance car.
