Torsion bar bolts uneven 68 b body #2903378
03/27/21 02:06 PM
03/27/21 02:06 PM
Indiana
68_661charger Offline OP
Indiana
I rebuilt the front end on my 68 maybe 10years ago and set the front level side to side but the drivers torsion bar bolt is turned in farther than the passenger side. Car is still level after all these years. Is this normal for the bolts to be in different lengths?
Re: Torsion bar bolts uneven 68 b body [Re: 68_661charger] #2903443
03/27/21 08:24 PM
03/27/21 08:24 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yes.
Angry white pureblood male
Re: Torsion bar bolts uneven 68 b body [Re: ruderunner] #2903454
03/27/21 08:50 PM
03/27/21 08:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That's why they are called adjustment bolts. If you had a coil design you would have to live with the non adjustable differences.
Re: Torsion bar bolts uneven 68 b body [Re: NITROUSN] #2903488
03/27/21 10:51 PM
03/27/21 10:51 PM
Indiana
Indiana
Ok thanks!
Re: Torsion bar bolts uneven 68 b body [Re: 68_661charger] #2903501
03/28/21 12:43 AM
03/28/21 12:43 AM
Boise
Moparteacher Offline
Boise
They shouldn't be too far different. Different is OK, but if it's drastic then it's a sign of a failing torsion bar or a weak or imbalanced leaf springs.
How much difference is acceptable is anyone's guess. I would suspect no more than a few turns. The adjustments on my 69 383 RR is almost identical.
Do the tires match side to side, same inflation side to side, no damaged or worn bushings, and cross caster within .5 degree? Take a real good look at the rear leaf springs as well.
Re: Torsion bar bolts uneven 68 b body [Re: Moparteacher] #2903505
03/28/21 06:16 AM
03/28/21 06:16 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Double check to make sure you have the correct numbered bars and have them on the correct side. There is a right and left to the bars.
Re: Torsion bar bolts uneven 68 b body [Re: fastmark] #2903507
03/28/21 06:48 AM
03/28/21 06:48 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
He put it together 10 years ago. If there was a problem then, it would have made itself apparent by now. That's not to say that a 50 year old bar won't fail.
If ride height is still ok, I certainly wouldn't worry.
Re: Torsion bar bolts uneven 68 b body [Re: ruderunner] #2903511
03/28/21 07:37 AM
03/28/21 07:37 AM
Indiana
Indiana
Yes still nice and level. I'll have to look at the rear springs and a few other things it looks like. I don't believe I took the bars out completely at all but it was 10 years ago. I'd say the difference on the threads showing is 1/2 inch. Car drives great, I was more curious as I noticed it when I was under it the other day.
Re: Torsion bar bolts uneven 68 b body [Re: NITROUSN] #2903519
03/28/21 08:28 AM
03/28/21 08:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and same as a coil from one side could get an earlier worn process than the other side, the T bars are the same. There is not a PERFECT matching process on every piece built/casted. One T bar could get cooler faster than the other when being templated, or some contamination particle or air buble trapped into the metal... whatever thing could happen
fortunatelly T bars are adjustable to easilly get the suspension leveled
Re: Torsion bar bolts uneven 68 b body [Re: NachoRT74] #2903594
03/28/21 12:49 PM
03/28/21 12:49 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
For reference, I was under my roadrunner today getting things ready for summer. My t bar adjuers are about 3/8th inch difference. Seems like you're in the ballpark.
Re: Torsion bar bolts uneven 68 b body [Re: ruderunner] #2903683
03/28/21 04:07 PM
03/28/21 04:07 PM
Indiana
Indiana
Great! Thank you for looking...
Re: Torsion bar bolts uneven 68 b body [Re: 68_661charger] #2909229
04/11/21 08:54 PM
04/11/21 08:54 PM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
you can clock the adjusters differently
Re: Torsion bar bolts uneven 68 b body [Re: NachoRT74] #2909345
04/12/21 03:30 AM
04/12/21 03:30 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
BTW, driver side of the car is heavier than passenger side. Steering box and parts, master cylinder and brake booster. Dunno how much woild affect that on the T bars adjusting.
Althought engine is offset to the passenger side by an inch or so.
Re: Torsion bar bolts uneven 68 b body [Re: NachoRT74] #2909383
04/12/21 09:15 AM
04/12/21 09:15 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Check and see if the long one is seated in the socket above. Common mistake.
1969 Hemi Roadrunner 2nd owner
Re: Torsion bar bolts uneven 68 b body [Re: 68_661charger] #2909402
04/12/21 10:15 AM
04/12/21 10:15 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
By any chance do you have SS springs in the back?
Re: Torsion bar bolts uneven 68 b body [Re: NITROUSN] #2909404
04/12/21 10:21 AM
04/12/21 10:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
grinder = adjustable..lol
Coming soon!!!!
