Dead Cylinders
#2907977
04/08/21 11:49 AM
04/08/21 11:49 AM
Posts: 1,534 Florida
CHRGR69
69 Charger 440 with electronic ignition conversion. I had a miss and pulled each plug wire at the cap and had no change in idle on cylinders 1,4,6 and 7. Carb was just rebuilt. ??
Grandma always said I had "hands of gold"!
Re: Dead Cylinders
[Re: CHRGR69]
#2908000
04/08/21 12:43 PM
04/08/21 12:43 PM
Posts: 5,839 ohio
ruderunner
ohio
Dirty carb. Sounds like a plugged idle passage. Dual plane intake correct?
Angry white pureblood male
Re: Dead Cylinders
[Re: ruderunner]
#2908012
04/08/21 01:20 PM
04/08/21 01:20 PM
CHRGR69
Stock 440 intake. Dual plane I assume
Re: Dead Cylinders
[Re: nick24]
#2908156
04/08/21 08:06 PM
04/08/21 08:06 PM
Posts: 5,839 ohio
ruderunner
ohio
Read above replies. That would be a huge coincidence if it was distributor related.
Re: Dead Cylinders
[Re: NITROUSN]
#2908340
04/09/21 09:38 AM
04/09/21 09:38 AM
Posts: 10,730 North Dakota
6PakBee
North Dakota
1,4,6,7 all feed on one side of the dual plane intake. Either a massive vacuum leak off the intake vacuum port [try capping it], or carb is plugged internally. If you have power brakes, this connection has bit me more than once when the booster failed and turned into a vacuum leak.
