Dead Cylinders #2907977
04/08/21 11:49 AM
04/08/21 11:49 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
69 Charger 440 with electronic ignition conversion. I had a miss and pulled each plug wire at the cap and had no change in idle on cylinders 1,4,6 and 7. Carb was just rebuilt. ??
Grandma always said I had "hands of gold"!
Re: Dead Cylinders [Re: CHRGR69] #2908000
04/08/21 12:43 PM
04/08/21 12:43 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Dirty carb. Sounds like a plugged idle passage. Dual plane intake correct?
Angry white pureblood male
Re: Dead Cylinders [Re: ruderunner] #2908012
04/08/21 01:20 PM
04/08/21 01:20 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Stock 440 intake. Dual plane I assume
Re: Dead Cylinders [Re: CHRGR69] #2908029
04/08/21 02:04 PM
04/08/21 02:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
1,4,6,7 all feed on one side of the dual plane intake. Either a massive vacuum leak off the intake vacuum port [try capping it], or carb is plugged internally.
Re: Dead Cylinders [Re: CHRGR69] #2908067
04/08/21 03:39 PM
04/08/21 03:39 PM
ca
N
nick24 Offline
nick24  Offline
N
ca
Sounds like ignition to me. You might have a carbon tracked distributor cap.
Re: Dead Cylinders [Re: nick24] #2908156
04/08/21 08:06 PM
04/08/21 08:06 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Read above replies. That would be a huge coincidence if it was distributor related.
Re: Dead Cylinders [Re: NITROUSN] #2908340
04/09/21 09:38 AM
04/09/21 09:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you have power brakes, this connection has bit me more than once when the booster failed and turned into a vacuum leak.
Re: Dead Cylinders [Re: 6PakBee] #2908343
04/09/21 09:47 AM
04/09/21 09:47 AM
VA
dragon slayer Offline
VA
Did distributor work fine before the carb build? If so, last change was the carb and worth checking out. If the conversion was recent to electronic too, then make sure not a Chinese poor quality one. Recently had one that missed fired a few cylinders. Had to change the pickup to original MOPAR and a new reluctor to fix it.
