Removing alum block cylinder sleeves #2907464
04/06/21 09:01 PM
04/06/21 09:01 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
How is it normally done, block goes in an oven ?
How hot ?
How do you grab the sleeve to pull it out ?
Putting sleeves back in is different, I think, don't the sleeves get super cooled
and block stays at room temp ?
Re: Removing alum block cylinder sleeves [Re: hemienvy] #2907484
04/06/21 09:33 PM
04/06/21 09:33 PM
How hot ?
Which brand and type aluminum block? Race or street block?
Most aluminum race blocks, water cooled blocks, are design to have the sleeves replaced at the races with a sleeve puller, same thing I think on the newer billet race blocks with steel or iron sleeves shruggy wrench
I'm not sure on the street aluminum blocks confused blush
Re: Removing alum block cylinder sleeves [Re: Cab_Burge] #2907497
04/06/21 09:51 PM
04/06/21 09:51 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hi Cab,
I didn't think it made a difference what brand of block, except maybe wet sleeve blocks, those I know nothing about.
In fact I thought they get installed with some kind of lube, they are a press fit in the block but not a super tight press fit,
or so I thought.
I don't see how you could press them out since you can't get to the bottom edge of the sleeve.
Re: Removing alum block cylinder sleeves [Re: hemienvy] #2907536
04/07/21 01:15 AM
04/07/21 01:15 AM
The race wet blocks have a provision machined in the sleeves to be removed and replaced with a sleeve puller.
I use to see it at the Winternationals years ago before the billet blocks replaced the race water blocks, the good pit guys could have them out and the new one in place in under 10 minutes thumbs
Re: Removing alum block cylinder sleeves [Re: Cab_Burge] #2907566
04/07/21 04:35 AM
04/07/21 04:35 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Bore the sleeve until it’s paper thin, then pull it out by hand.
69 GTX 68 Road Runner
Re: Removing alum block cylinder sleeves [Re: JERICOGTX] #2907586
04/07/21 08:23 AM
04/07/21 08:23 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
That is how my machinist does it. If it is an aluminum block, sometimes you have to get a replacement sleeve a few thousandths bigger in the outside diameter to compensate for warpage of the block, during replacement.
Re: Removing alum block cylinder sleeves [Re: jwb123] #2907605
04/07/21 09:24 AM
04/07/21 09:24 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Wow, I guess I was thinking the sleeves were reusable, apparently not !
Re: Removing alum block cylinder sleeves [Re: hemienvy] #2907669
04/07/21 12:29 PM
04/07/21 12:29 PM
Texas
Chief Online content
Chief  Online Content
Texas
Let me share my .02 worth of knowledge..
On my KB solid block the sleeves are pressed in with something like .005 interference fit. On a water block if the sleeve is against the water it has to be sealed at the top and bottom, if it is a dry sleeve it is like my KB. Indy water block is dry sleeve and it is interference fit.
I helped replace a sleeve in a Allen Johnson Billet block ina TD car, sleeve was frozen overnight, I stood with a weed burner torch in the hole to heat the block then sleeve was started and a 20 lb sledge used with a block of wood to drive it in.
I asked the question why didn't the engine have to get machined afterwards. I was told the sleeve (Darton) was bored and honed at the factory for that blocks measurements and when if was put in it would have the correct bore and finish.
Guess what? Piston went in with the correct clearance car set a new TD record the following weekend. eek
And that's about the extent of my knowledge other than my Indy block is having 3 sleeves replaced after the damage is repaired..lol
Dave Covey
Re: Removing alum block cylinder sleeves [Re: hemienvy] #2907671
04/07/21 12:31 PM
04/07/21 12:31 PM
Texas
Texas
Not usually put back in the same block. I bought 8 sleeves from a guy that were a bigger OD than what was in my KB block. I had the block bored to accept the sleeves, then bored the sleeves to 4.5.
Original sleeves were 4.375 but were to thin to bore to 4.5, so I had to go bigger OD.
Dave Covey
Re: Removing alum block cylinder sleeves [Re: hemienvy] #2907692
04/07/21 01:36 PM
04/07/21 01:36 PM
PA
RBRE Offline
RBRE  Offline
PA
We have a large kiln we can heat the blocks in. Heat to 250 degrees for an hour. Remove block and the sleeves fall out onto the floor. Sometimes just a hot jet wash will do the trick. I have also seen people use a torpedo heater. To install the sleeves we heat the block to 250 degrees and use a Coleman cooler that can hold eight sleeves standing on end and fill the sleeves with dry ice pellets. Costs about $25. Leave in cooler for ½ hour. Wear welding gloves and the sleeves just drop into the block even if it’s an iron block. Doesn’t distort other cylinders. No sledge hammers required.
Ray Barton
Re: Removing alum block cylinder sleeves [Re: RBRE] #2907841
04/07/21 09:01 PM
04/07/21 09:01 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Ray Barton
iagree Not that you need my vote of approval. I have both KB block(s) and an Indy block. Sleeves in the KB are "O" ring fit water blocks (run dry) and basically pop in and out with minor effort. I have yet to need to pull a liner on the Indy block but as stated above and since Alum expands and absorbs heat (in this case) at twice the rate of steel I would imagine that when un-constrained by the cylinder head they would essentially drop out of the block when heated.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Removing alum block cylinder sleeves [Re: hemienvy] #2907934
04/08/21 09:29 AM
04/08/21 09:29 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They were back in the days of "wet sleeve" blocks. Now it's done as Ray described.
2011 Drag Pak Challenger
Re: Removing alum block cylinder sleeves [Re: rickseeman] #2907937
04/08/21 09:43 AM
04/08/21 09:43 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Here is a picture of the sleeves that were damaged in my block. One had a dent from the rod hitting it. It would not have come out with heating it up, and why it was machined out.
