Re: Removing alum block cylinder sleeves
[Re: hemienvy]
#2907484
04/06/21 09:33 PM
04/06/21 09:33 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
How is it normally done, block goes in an oven ? How hot ? How do you grab the sleeve to pull it out ?
Putting sleeves back in is different, I think, don't the sleeves get super cooled and block stays at room temp ? Which brand and type aluminum block? Race or street block? Most aluminum race blocks, water cooled blocks, are design to have the sleeves replaced at the races with a sleeve puller, same thing I think on the newer billet race blocks with steel or iron sleeves ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) I'm not sure on the street aluminum blocks ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif)
[Re: hemienvy]
#2907536
04/07/21 01:15 AM
04/07/21 01:15 AM
Cab_Burge
The race wet blocks have a provision machined in the sleeves to be removed and replaced with a sleeve puller. I use to see it at the Winternationals years ago before the billet blocks replaced the race water blocks, the good pit guys could have them out and the new one in place in under 10 minutes ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Cab_Burge]
#2907566
04/07/21 04:35 AM
04/07/21 04:35 AM
Posts: 10,049 MN
JERICOGTX
MN
Bore the sleeve until it’s paper thin, then pull it out by hand.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2907586
04/07/21 08:23 AM
04/07/21 08:23 AM
Posts: 884 Missouri
jwb123
Missouri
Bore the sleeve until it’s paper thin, then pull it out by hand. That is how my machinist does it. If it is an aluminum block, sometimes you have to get a replacement sleeve a few thousandths bigger in the outside diameter to compensate for warpage of the block, during replacement.
[Re: hemienvy]
#2907669
04/07/21 12:29 PM
04/07/21 12:29 PM
Posts: 201 Texas
Chief
Texas
Let me share my .02 worth of knowledge.. On my KB solid block the sleeves are pressed in with something like .005 interference fit. On a water block if the sleeve is against the water it has to be sealed at the top and bottom, if it is a dry sleeve it is like my KB. Indy water block is dry sleeve and it is interference fit. I helped replace a sleeve in a Allen Johnson Billet block ina TD car, sleeve was frozen overnight, I stood with a weed burner torch in the hole to heat the block then sleeve was started and a 20 lb sledge used with a block of wood to drive it in. I asked the question why didn't the engine have to get machined afterwards. I was told the sleeve (Darton) was bored and honed at the factory for that blocks measurements and when if was put in it would have the correct bore and finish. Guess what? Piston went in with the correct clearance car set a new TD record the following weekend. ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) And that's about the extent of my knowledge other than my Indy block is having 3 sleeves replaced after the damage is repaired..lol Dave
Dave Covey
[Re: hemienvy]
#2907671
04/07/21 12:31 PM
04/07/21 12:31 PM
Posts: 201 Texas
Chief
Texas
Wow, I guess I was thinking the sleeves were reusable, apparently not ! Not usually put back in the same block. I bought 8 sleeves from a guy that were a bigger OD than what was in my KB block. I had the block bored to accept the sleeves, then bored the sleeves to 4.5. Original sleeves were 4.375 but were to thin to bore to 4.5, so I had to go bigger OD. Dave
Dave Covey
[Re: RBRE]
#2907841
04/07/21 09:01 PM
04/07/21 09:01 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
We have a large kiln we can heat the blocks in. Heat to 250 degrees for an hour. Remove block and the sleeves fall out onto the floor. Sometimes just a hot jet wash will do the trick. I have also seen people use a torpedo heater. To install the sleeves we heat the block to 250 degrees and use a Coleman cooler that can hold eight sleeves standing on end and fill the sleeves with dry ice pellets. Costs about $25. Leave in cooler for ½ hour. Wear welding gloves and the sleeves just drop into the block even if it’s an iron block. Doesn’t distort other cylinders. No sledge hammers required. Ray Barton ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Not that you need my vote of approval. I have both KB block(s) and an Indy block. Sleeves in the KB are "O" ring fit water blocks (run dry) and basically pop in and out with minor effort. I have yet to need to pull a liner on the Indy block but as stated above and since Alum expands and absorbs heat (in this case) at twice the rate of steel I would imagine that when un-constrained by the cylinder head they would essentially drop out of the block when heated.
![Name: sleve puller.gif
ID: 423703 sleve puller.gif](/ubbthreads/ubbthreads.php/ubb/download/Number/423703/filename/sleve puller.gif)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: hemienvy]
#2907934
04/08/21 09:29 AM
04/08/21 09:29 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Wow, I guess I was thinking the sleeves were reusable, apparently not ! They were back in the days of "wet sleeve" blocks. Now it's done as Ray described.
2011 Drag Pak Challenger
[Re: rickseeman]
#2907937
04/08/21 09:43 AM
04/08/21 09:43 AM
Posts: 10,049 MN
JERICOGTX
MN
Here is a picture of the sleeves that were damaged in my block. One had a dent from the rod hitting it. It would not have come out with heating it up, and why it was machined out.
69 GTX
68 Road Runner
