Re: Tire clearance
[Re: Wirenut]
#2905491
04/02/21 05:24 PM
04/02/21 05:24 PM
Posts: 16,491 On the run…
BloFish
On the run…
1” is a safe bet. That’s as close as I want to be.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: Tire clearance
[Re: Cab_Burge]
#2905592
04/02/21 09:34 PM
04/02/21 09:34 PM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
On my Valiant I can barely squeeze my fingers between the inner fender and the sidewall. They have never touched. Coilover/ladder bar car.
Re: Tire clearance
[Re: Wirenut]
#2905700
04/03/21 10:14 AM
04/03/21 10:14 AM
Posts: 3,087 Michigan
A727Tflite
, How close would you dare to get bias slick to a wheel opening? Are you asking about clearance to the wheel opening ? Or the side walls to the inner or outer wheel house and/or leaf spring ?
Re: Tire clearance
[Re: A727Tflite]
#2907469
04/06/21 09:07 PM
04/06/21 09:07 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
It depends where is the tight clearance. Inner wheelwell needs miles of room due to articulation. As the axle articulates, the tire travels in an arc towards the center of the car. To the leaf can be very close because they move together. Tire to outside at top can again be close because not much is going to push it towards the body. The leading or trailing edge of fender to a slick needs room because they grow with rpm.
