Tire clearance #2905452
04/02/21 04:23 PM
04/02/21 04:23 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
How close would you dare to get bias slick to a wheel opening?
Re: Tire clearance [Re: Wirenut] #2905491
04/02/21 05:24 PM
04/02/21 05:24 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
1” is a safe bet. That’s as close as I want to be.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Tire clearance [Re: Wirenut] #2905522
04/02/21 06:20 PM
04/02/21 06:20 PM
Middle finger width while using caution on turns twocents scope
More clearances are better, especially for street driving up
Re: Tire clearance [Re: Cab_Burge] #2905592
04/02/21 09:34 PM
04/02/21 09:34 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
On my Valiant I can barely squeeze my fingers between the inner fender and the sidewall. They have never touched. Coilover/ladder bar car.
Re: Tire clearance [Re: slantzilla] #2905672
04/03/21 09:17 AM
04/03/21 09:17 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
On my Dart I had a knuckle's worth, a tight one at that, of clearance between the leaf and the rolled inner fender lip. I was running some tall sidewall bias plies and the sidewall would just rub the side of the leaf pack in hard turns. If I had a shorter/stiffer sidewall it would not have hit at all.
Slicks tend to get taller and narrower as they are spun up so in a straight line you'd get a bit more clearance. In turns, well go slow.
Re: Tire clearance [Re: Wirenut] #2905700
04/03/21 10:14 AM
04/03/21 10:14 AM
A727Tflite Offline
A727Tflite  Offline
Are you asking about clearance to the wheel opening ?
Or the side walls to the inner or outer wheel house and/or leaf spring ?
Re: Tire clearance [Re: A727Tflite] #2907469
04/06/21 09:07 PM
04/06/21 09:07 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It depends where is the tight clearance. Inner wheelwell needs miles of room due to articulation. As the axle articulates, the tire travels in an arc towards the center of the car.
To the leaf can be very close because they move together.
Tire to outside at top can again be close because not much is going to push it towards the body.
The leading or trailing edge of fender to a slick needs room because they grow with rpm.
