03/30/21 03:22 PM
03/30/21 03:22 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
HI
anyone use a 8 1/4 rear 4:56-4:88 for drag racing with slicks 4000lb car? 400-500 hp mark Williams can make axles for me 27 spline
thanks gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 8 1/4 [Re: 440lebaron] #2904313
03/30/21 03:26 PM
03/30/21 03:26 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I think you would be better off spending your $ to upgrade to a better/beefier rear end. I just don't see a 8 1/4 lasting very long under those conditions.
Re: 8 1/4 [Re: DusterKid] #2904316
03/30/21 03:32 PM
03/30/21 03:32 PM
westerly, ri. usa
westerly, ri. usa
using for nhra stock, can get S60 from doctor diff, kinda heavy plus takes extra hp to turn
Re: 8 1/4 [Re: 440lebaron] #2904318
03/30/21 03:38 PM
03/30/21 03:38 PM
an8sec70cuda Offline
But you'll never break it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 1/4 [Re: an8sec70cuda] #2904339
03/30/21 05:02 PM
03/30/21 05:02 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Would a Chevy 12bolt rear be legal in your class? I remember several years back a few guys were using them in some Hemi Abodies. They are lighter than a Dana,absorb less power than a 9inch (attractive to a class racer)
and tons built. Should be able to build one to easily handle 400-500hp reasonably.Lots of used stuff also. Just a thought -if it's legal for your class. Bill
Re: 8 1/4 [Re: lancer493] #2904397
03/30/21 09:03 PM
03/30/21 09:03 PM
westerly, ri. usa
westerly, ri. usa
Legal super/stock, stock no needs to be same make as body
Re: 8 1/4 [Re: 440lebaron] #2904400
03/30/21 09:17 PM
03/30/21 09:17 PM
westerly, ri. usa
westerly, ri. usa
I can deal with changing ring and pinion each season as maintenance, just don't want to spit out pinion on starting line
Re: 8 1/4 [Re: 440lebaron] #2904427
03/30/21 10:52 PM
03/30/21 10:52 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
i ran a 8-1/4'' for years behind a 410'' stroker in my 3980 lbs. Aspen R/T. around 450 hp. 28/9/15 MT slicks
Re: 8 1/4 [Re: 440lebaron] #2904488
03/31/21 09:12 AM
03/31/21 09:12 AM
What about an 8.75? Those can be had for cheap. I'd feel much more confident w/ that. twocents
CHIP
Re: 8 1/4 [Re: an8sec70cuda] #2904587
03/31/21 12:43 PM
03/31/21 12:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree scope
if race only buy the 35 spline spool and axles and a steel cap for the drivers side and maybe a back brace if the car hooks and 60 ft. real hard scope twocents
Re: 8 1/4 [Re: 440lebaron] #2904899
04/01/21 12:10 PM
04/01/21 12:10 PM
Locomotion Offline
Locomotion  Offline
Saw your thread on classracer.com too.
I believe you would have to get a c-clip eliminator for the 8 1/4" rear because I'm pretty sure they are illegal (unsafe) under NHRA rules.
As mentioned by others, a Dana 60 won't slow you down much, if any at all. Most people I've heard commenting on the change didn't lose anything and some claimed to be slightly faster! It is a more efficient rear than the 8 3/4" (Takes less HP/torque to turn.) because of the location of the pinion contact relative to the ring gear. A Chevy 12 & 10 bolt are more efficient and a Ford 9" is the worst, but of course they aren't legal. 81/4" might be pretty efficient, but weaker, minimal ratio choices and fewer aftermarket parts. Overall weight is really irrelevant because the car has to be run at a minimum weight with driver anyway. Plus, the weight is in the back where it will do the most good. When you start replacing internal parts with aftermarket pieces that are lighter, the weight difference between a Dana 60 and 8 3/4" shrinks - (i.e.:lightened ring gear & spool, ) because the Dana 60 parts weigh more to begin with. Axles can be drilled and lightened in the flange area in either type. You also don't need a back-brace for a Dana 60 like you should have for an 8 3/4", bringing the 2 even closer in weight. Only down sides I see is that you need to get the gear ratio correct the first time and swapping gears is not as easy. Easier to get PRO gears for a Dana 60 as well. But either can have cryo and/or Superfinishing done for longer life.
I believe in the benefits of a Dana 60 enough to have installed one in my K/SA Aspen Wagon.with a 360 at a minimum weight of 3,927 starting out in the 12's! Got one for my trusty Dart Sport @ 3,530 minimum weight for IHRA Stock capable of low 11's. But that one hasn't been installed yet and don't know if I'll be out with either one anyway.
Get a Dana 60. It will be better and cheaper in the long run.
Re: 8 1/4 [Re: Locomotion] #2904903
04/01/21 12:18 PM
04/01/21 12:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t think anyone sells a c clip eliminator for a 8 1/4. I looked some years ago and never found one.
